Spotted a gunmetal 32 gtr turning onto Grenfell, completely standard apart from side wing extenders and the additional "use with your stock spiler" boot lip. God those wing extenders need to die a firey death (IMO)
That would be me - Indoor soccer Tuesdays at the rec center.
me too lol, suprised i havent seen you there before...rebound or futsal?
will have to meet you at some point :) unless we have already played against each other haha
white 32 gtr (but no badges..) belair rd this morning about 8.45
black 33 boosting down greenhill rd near unley rd at 6pm
Rebound, playing for the red hot llamas or something of that sort.
Black R33 gtr driving around TTP shopping center 4pm today.
ohkay, im futsal :)
geez, ttp long way from blackwood lol
I live in Norwood. only drive to blackwood for rebound cause its with some work friends and well.. who can refuse a drive through the hills? :(
That was me in the stagea i cant remember if i saw you or not
You were in front of me the entire time so you probably didn’t notice me. I was in the silver R33 behind you :down:
Spotted today a black R32 turning off Fullarton Rd onto Cross Rd around 12:30pm or so, don’t remember the exact time. Also on my way back down Fullarton Rd spotted a black R33 GTR around 2pm, again didn’t take note of the exact time.
spotted that fpos r33 with hydraulics gettin pulled over by the uc's today
SUCKED IN.
i saw that same one was it a gun metal gray colour and where the skyline embelem goes did it have bazza on it i saw it last friday at grand junction and i scream out "you a total f**kwit" and the mullet wearing twat didn't like that
Spotted Matty31 and nightcrawler last night driving north bound down south road yesterday at about 7:40pm (ish) after what I can assume dinner at Villies? I was right next to you but I was ninja spec in my mums commodore lol :P
haha, we were heading to cartoys (think it was somewhere there that Luke_ENR34 deafened me with a keybanger from the uterus)
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
