Ahh nice. Yes she was rather sunk back in her seat, I doubt she could have seen naught.
I love the choice of rims to match the paint, I reckon theyre bigger than the stocko 32 gtr rims, but most def your 31 is very tidy and if I didn't have the GTR I would be considering buying one (my first car was a s3 r31 that I dropped mad coin on till I wrote it off)
-D
I think the factory SVD mags are 16 x 7.5, and i'm sure one of the trolls on here will correct me if i'm wrong, but I thought 32 gtr were 16 x 8. Would have looked cleaner from the other side. The left hand side has been re-painted. lol.
Anyway... I'll stop whoring up your spotted thread with my 46 posts.
Absolutely wicked looking red 32r on Brighton road driven by an elderly man. Could've been sprayed candle apple red not sure but was definitely not standard colour. And just saw vu's 32 parked on jetty road... Good to see it close up looked nice (y)
spotted Zeke yesterday arvo at the bottom of my street just about to turn onto seacombe road...........went cruising past in something a bit bigger and greener so didnt get a chance to get to the horn
but i did get to the horn about half an hour later near morphettville racecourse, spotted Kahli and a blue M35 Stagea with gold AVS wheels. I saw u look a bit confused hahahaha
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
