removed everything down to the sound proofing muck on the floor, 4w steer long gone, all unused brackets bolts heat shields.
fuel tank when today and put a fuel cell in and that alone will be the best part of 15kg i think.
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3651256
if rules allow for it maybe remove the rad support and front and rear reinforcement bars and replace with chromolly tubing. also maybe start drilling holes in flat non structural body panels and dimple die'ing it.
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3651378
Yes that all long gone.
door windows winders motors etc are gone door trims too still need to take the hole saw to the door frames though.
I do have a substancial cage in the car though so there would be 30 odd kgs in that.
Looks like some gram light wheels and carbon fibre bonnet and boot are next
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3651852
a few other things you may or may not have taken out,
rear wiper and motor.
In mine I stripped back the entire wiring loom and removed all the excess wiring that is now not used. There was a substancial ammount of "free" weight there. You can halve the wiring under the dash easily.
ABS been removed and the assosiated wiring??
Running a full exhaust still or side pipe??
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652135
There is not a great deal you can do without besides the ABS, air conditioning etc its more about saving weight.
Besides the obvious, you can strip the loom and rewire with the bare essentials. you'd be suprised how much wiring is unused once you remove the HICAS, ABS etc.
Single turbo conversions are lighter than typical twins.
Stick with alloy piping if possible.
Carbon canisters can be removed as well as the piping
Heater hoses and other water lines if you have stripped the inside out
Washer bottle and hoses.
Smaller battery
You can pretty much take anything out thats not needed if your building a circuit car.
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652376
gee... i dont know how come ours is so heavy?
our car still weigh's 1380!
carbon boot
carbon doors
carbon airfilter box
no dash cluster
carbon panel and stack dash
one seat
no air conditioning
no abs
no hicas or pumps
nothing behind the dash
lexan door windows
no interior at all
some internal panels cut out
all bumper reinforcement gone
no rear wiper or motoboot and bonnet cathes gone
all boot hinge mechanism gone
most brackets gone
not sure how i could lose another 100 kilo, let alone 150!! :)
Edited by giant
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652436
If its a track car then i think you would be silly to remove ABS.
Thats only my 2c...along with the fact that everbody seems to be obsessed with removing weight, which is fair enough. But no one ever seems to consider that you can do a hell of a lot with relocating where the weight is located. ie moving it lower in the car or into the cabin/centre of the car
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652450
you have a pretty comprehensive cage in it though.
Mine only had a rear jap half when it was last weighed. besides the carbon pannels mine is as stripped as your car.
There is always the chance of errors on the scales behalf as well I guess (public weigh bridge in my last case)
https://www.sau.com.au/forums/topic/206293-gtr-r32-weight/#findComment-3652571
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
