im about to fit a lexan passengers window and remove the drivers (will use a net instead) You have to retain a glass windscreen for saftey in most events.
By the time you remove the glass, motor, regulator and wiring assosiated with it there can be decent savings per door.
Ive also removed all the old steel lines this week and replaced with alluminium/ speed flow fittings.
The steel ones are really not that heavy but the alloy is lighter and its fresh.
Andrew whilst you not using that headlight can I borrow it and make a mould? I want to make a carbon item but cant find a decent one to mould it from.
yeah no worries!
i wouldnt mind having a peek at that dry sump you have there.
not long now till the motor is here!
No worries, next time you have a free weekend come past home an check it out.
The whole engine is sitting out atm so its pretty easy to see how its all been set-up prior to being fitted to the car.
Im still working the small bugs out that I ran into on a spare engine before fitting into the car for the last time.
Biggest problem im having is the actualy sump pan and scavneger.
Aaron was telling me about the engine you have coming over, sounds like you found a half decent buy with it, well done.
If you want to offload the old donk let me know, may be interested as a 2nd spare.
Edited by Risking
All we did for the lexan windows was use a strap buttoned to the window from the inside and then velcro it to the roll cage to keep it tight, only downside to this is trying to put some tension(from the outside) on them when transporting the car. otherwise it works well.
Yeah i'll come over some time this week if thats good!
this is what i picked up Apparently a 34 N1 motor that was possibly rebuilt, and put into a 32 bought, then smashed after 3000km of ownership.
Edited by Angus Smart
yer but skyline windows are hard to fit due to a frameless door and they have to be made out of 5mm material and are thermo formed to get correct curve.
easy to form them just put in boiling water for a few minutes then clamp it to the original glass to cool. would be 15 or more kgs in weight saving from all glass being replaced
from all glass?
i removed the front windscreen from the r32 shell and its 10 kgs,i'd say rear windscreen would be 10kgs or more.
so if the plastic weighs 1-2 kgs each replacement, you cud end up saving 18-16kgs from just the front+rear windscreens alone
how much do door windows weigh? (i dont have a spare one)
i have seen r32 gtr in option videos weight 1000-1100kg cool.gif i see if i can find which one it is in and upload it
if ya do www.megaupload.com
Edited by Dan_J
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
