  • Replies 40
Here in Perth
Toyo Proxes T1R 235/45/R17 = $230ea
Maybe cheaper over east.
I previously ran Toyo Trampios 235/45/R17 and had some trouble with traction after upgrading to HKS2835ProS with 255rwkw.
With the T1R's on the back I can now give it full stick in first and second with minimal if any wheelspin.
I cant vouch for Proxes4 but they are only $10 to $20 cheaper at most.
Trampios were a pretty good tyre to begin with but T1R's after definately better again.
I am no longer getting the rear sliding out at Motorkahana's.
Others are getting very good results with T1R's for hillclimbs and Targawest.
can I ask approximately what they cost, and in what size? I will quite likely need more soon!!! :D
With the proxes4's on the rear I can now 'almost' get all of second down. 3rd doesn't give the slightest hint of letting go.
First gear is still pretty useless but with half throttle it seems to hook well, short shift to second and then be a little soft on it.
Trent, what Toyo tyres were on the S13 that Baron purchased. He was kind enough to give me a steer at PI and the tyres put up with about 5-6 laps and were still way better then i expected.
PS...hats off to the way that car is screwed together. Its a great car! :)
cheers, im glad you enjoyed driving it... it was hard to let go for both me and cat :P and seeing the pics at PI of all places made me regret it more :P
i like the proxes 4 but the T1r's are a bit better (less tread squirm) but the proxes 4 do everything we need them too.
cheers, im glad you enjoyed driving it... it was hard to let go for both me and cat :P and seeing the pics at PI of all places made me regret it more :)
Don't be sad. Both you and Cat have an open invitation to drive it any time you are up in Sydney. we can do EC or Oran Park. they aren't quite PI but still good fun. :P
well I don't want to whore up the thread too much, but I did at least give one helpful reply!
I bought an S13 silvia. quite a few mods. but some of the main ones: SR20, 2 way lsd, Trust T518Z, stainless mani, Blitz/ORC clutch, PFC, 550injectors, Z32 AFM, S14 box, coil-overs, 5 stud conversion, R33 brakes, FMIC, trust exhaust, Uras N+ kit etc. took it to phillip island on the weekend. and I will see you at some drift practice soon! seems all the cool kids are doing it, and you can show me how! I'm novice. :rofl:
very nice. i was going to say those mods and u arnt going to be driftng it. youve got the perfect car to do it in. i will help you on your beginers journey.:/ nudge nudge.also give the wheel to chris and let him give u a few pointers. he's usuallly out at the IDA prac days.
ahh yes and the tyres! that was what this thread is about! wasnt it?
  • 1 month later...
I bought some t1rs for the fronts last year on my buddyclub p1s.
Excellent rubbers for track and normal road use.
T1rs have a lot off grip and i highly recommened them. Also they didnt seem to wear out quickly either- actually still had like 7mm of thread left after ages with one track day!!
GO BUY IT!!
I'm really happy with the proxes4. BUT they do tend to squeel a tad especially when hard on the brakes.
I can brake hard enough so that they are constantly squeeling but not locking. Quite a progressive feeling tyre.
No doubt t1r's are better but none the less these proxes4 are still excellent value for the $$.
Next time.. I'm now can't wait to try the t1r's considering how good these proxes4 are. :D
  • 1 month later...
  • 5 months later...
Well, i've got the T1R's, only in 205/55/R16 so they're not very big. Ummm they've been pretty good, Awesome traction for a road tyre. The Proxes 4's were $10 cheaper than the T1R's in the same size at the time i bought mine.
There's some drifters in the Toyo drift series using the proxes 4's to drift on. The twin turboed LS1 R34 (the red one, i can't remember the team name or driver) uses them. Apparently they're quite consistent when used for drifting and when the tread wears down. As for street use, ican't comment on that. But it can't be bad.
I figured for myslef, why not get toyo's flagship tyre for just the few extra $$. Well it was only $10 per tyre for me at the time. Plus the wet weather grip was unbelievable. I've got the usual 190-200rwkw, on a soaked wet bituman(not even hot mix) on a standard take off not dumping the clutch, it would grip under full acceleration and not even lose traction on gear changes. Pretty good in my books. Great aquaplaning resistance too.
One thing i did notice, as soon as i got them on the car, in just regular driving and harder driving (twisties) you could feel that the tread was quite soft and there was a quite noticable extra amount of side to side movement in the tread. But this icky feeling soon dissappeared after a couple of weeks and some driving on them.
So thats all the experience i have to offer.
I've only run the Proxes 4 on my rear wheels (until the front ones RE01s are replaced) and during the Putty Rd Cruise and going up and down Hawkebury Hts, I'm getting quite a deal of side to side movement in them as you said. This happens especially as the tyres heat up. It's quite disconcerting. I'm running 37lb pressure in them as well. I'm wondering as to whether I should replace the fronts soon with T1Rs instead??? Or do you think that after another 500Km (since they've done 500Km already), they should settle down???
Thanks for advice.
Tez
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
