  • Replies 62
very nice results mate looks like it would be very quick on the street, looking at a similar package as yours, got the microtech and everything else, just dunno which turbo as yet but i'm after sumthing fun to drive on the street and the gt-rs certainly looks fun,
does anyone know of a decent tuner of microtech in brisbane, because everyone i talk to regards them as being a bit rough, but obviously it comes down to the tuner, just trying to find one who specialises in them at the moment.
Nice result! cant wait to get mine tuned :D, only 25days away lol
What fuel? and are you still using the stock dump and front pipes or after market?
Just on BP 98 Octane, wish we had some of that 100 Shell fuel up here :/
Yeah aftermarket all in one bellmouth 3" dump pipe.
You'll love it man, IMO its probably one of the best sized turbos you can go on a RB25 with getting good power out of it and being very responsive at the same time. Very good street driving.
Here's mine...
dangerman, you're an idiot :ermm:
for starters you can't even see how much power its making at 60km/h, and even if you could I doubt the postie bike makes anywhere near that.
Thats also where the graph starts, which means thats where the tuner accelerated...before that he was cruising in 4th gear. Well done, moron :D
is that cos its microtech or cos its map sensor thats its poo ?
map sensor is fine
it doesnt have idle up when cold, so it makes it hard to tune when its dead cold, but with abit of time you can get it so its perfect.
map sensor is fine
how long did it take him to tune start to finish? Also what did your tuner do about knock? or did he just stay conservative enough not to have to worry about it?
He listened for knock electronically (not sure the exact name of the machine they use, im sure someone here knows though), and there was no knock. The tune was done safe to accomodate for hot days up here.
Well he had it for 2 days just so he could get it right and i told him he could have it for as long as he wanted, he also road tuned it to get it driving perfect and spent a few hours on idle alone to get it perfect. He went out of his way to make me happy with it and he succeded greatly. Only person i will use in Townsville now for any work that i can't do myself.
F@#* dangerman that just shit comment but that's my opinion.
any way i found my last dyno with my torque level, id like to see a post bike like this,even some larger turbos don't make torque like this...
Edited by WARLORD
Just on BP 98 Octane, wish we had some of that 100 Shell fuel up here :)
Hehe i dont have a gt-rs, that was my orignal choice and i was dead set on it after reading what everyone thought about them, but after doing hours of research it seemed the hks 3037 pro s was the better overall option, so thats what i went for :D , my aim is 270-280rwkw with a nice safe tune, only downside is im going to be running 95octane (all we have in my town which sucks) so i might need a little bit over 1bar to make that power, should be perfect for the street/track in my opinion.
Anyway awsome result man!:D
I really dont know how much to read into torque
This was my readout with standard everything really
it is an auto and in second gear i think that make abit of a difference with gear ratios etc ( not sure the exact ratio of 2nd compared to a manual in 3rd gear)
Hmm something dodge with that torque readout. Maybe some others more knowledge than I can explain how it could read that. Maybe the one above is also subject to discrepancy via how its measured... but stock doing 800Nm is a 'off' looking lol Also... you're power looks insanely high for a stock GTT/GTST type engine. Aren't dyno runs usually done in 4th or 3rd? Don't recall seeing one in 2nd before.
Maybe this is why my mechanic said he doesn't usually bother measuring torque cos it depends on the dyno setup too heavily? or how its used... or something
Edited by sl33py
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
