flex pipe is usually used in FWD cars or cars with engine in east west config.
it essentially allows for the slight movement of the engine when you accelerate and back off etc.
looks like this.
On a front pipe, this would be at the point where the pipe bends towards under the car.
so off the turbo, bend down towards the ground, then at the bend back up to run under the car is where it goes.
it's to prevent exhaust from cracking at welds etc.
if you look at your engine when you rev it, it will lean to one side and back when you get off the pedal.
because most east west config engines have the exhaust at the front (some never ones have them at the back of the engine like the new Mazda 3 MPS), when you rev, the motors leans back and forth instead of left to right like a north south engine (eg RB and SR series of engines or any rwd car).
the back and forward movement of the engine pulls and pushes the exhaust.
the side to side movement doesn't cause this issue as
Edited by GTST
https://www.sau.com.au/forums/topic/207242-flex-pipe/#findComment-3666808
single turbo probably isn't important, but twin turbo / gtr setup you should never use a front pipe without flex on one of them. lets the turbos move a little independantly without cracking the warping/manifolds or exhaust
https://www.sau.com.au/forums/topic/207242-flex-pipe/#findComment-3669526
What about solid pipes on the RB25DET from AFM to turbo? I think the flex in the rest of the stock piping does the equivalent job of the flex here right?
I had a Civic with a solid pipe instead of the flex pictured above - it meant a small exhaust leak and a terrible whizzing noise until I got some flex put back in there... which is when they noticed a blocked up home-made oil return on the sump... They reckoned it had been turbo'd, or at least attempted, and then reverted back to normal! :(
https://www.sau.com.au/forums/topic/207242-flex-pipe/#findComment-3671150
  • 1 year later...
Can i be the first to say an exhaust shop Greg? :D
I've really never seen much of a quality difference between flex pipes of my various exhausts and they all came from difference places so there must be some sort of 'way its done' out there
https://www.sau.com.au/forums/topic/207242-flex-pipe/#findComment-4648179
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
