Just wondering about the different types of in-car camera mount designs people have used and had experiences with. I'm curious to see what mounting methods people have found to work best for in-car footage.
There's two main styles of camera mount I've seen: clamping style (clamp on to roll bar) or suction cup camera mount (manfrotto, chasecam, etc.)
Also interested in peoples AV setups, such as the type of equipment used, e.g. camcorders, bullet cams, external mics, video recording onto SD/flash, etc.
Post some pics if you can! :)
https://www.sau.com.au/forums/topic/208608-car-camera-mounts/
  • Replies 70
nice, adz one is pretty trick. I use this one:
http://www.rivergate5speed.com/vs_camera_mount.html
it's billet alluminium, very strong and works pretty well. it wouldn't pass for door to door racing, but I've never had a problem with scrutineering at any CAMS run supersprints i've attended with it.
www.stickypod.com - ive got a pro pak - have used it at a few DECAs and works well..(even on the outside/on roofs), use it for handycams, etc..
ive also just got one of those bullet cams, arrived today..
records directly to my 80GB archos media player... the camera itself weighs about 100g and is easy to attach to anything so should be good to test..next track day.
Ive always been suss of the ones that hold the camera on the outside of the car - have you had any issues with it Aaron?
Nah steve no issues, that said its only been used outside at deca/street etc...not at an actual track day..i doubt scruitineers would like it haha
If anything i'd use the little bullet cam for outside now. Yet to test..but eager to see how it goes..
depends what sort of camera you wanna mount too...
matt what you going to use? a handycam?
Well since your GTR is wounded at the minute, throw your mount in your bag for the GP. I want to try it at PI later this month, need to see if the angle and perspective in the cabon is right before buying one. My money is that unless i havea fancy camera it will be too close to the screen and all you will see is windscreen, no dash, gear changes or steering input ????
I was going to say that one... ...I've been looking at investing in a Stickypod setup... ...But using my CC on the net still feels doggy to me...
And I haven't found any good reviews that are not linked to the web site...
Hahaha!!!... ...Gold... ...That's how I'd hang lights in the Arts Centre when I'd ran out of clamps...
What did you mount on it?
Ive got one of these HDD ones:
hey i was looking at some killer av car gear before i left autobarn,
2ch av in for bullet cams
12volt
and sd card memory.
It was about the size of a ciggy pack. i will find some pics.
i could not find the exact one but i will keep searching.
Its pretty good, bit on the large side..i reckon the smaller one would be better...expensive too..does the job for me though.
examples:
outside on scotts roof - http://au.youtube.com/watch?v=VdXCvYNUZyU
outside on scotts door - http://au.youtube.com/watch?v=r6YIGiVl9q8
outside on my rear quarter window - http://au.youtube.com/watch?v=putvYexTtFQ
inside adz(max) rear window - http://au.youtube.com/watch?v=rqwrgPg1ojg
ive used it for my DSLR as well.
on a panel..
then you can go bullet cams as well which are probably the way to go..bit on the pricey side...i'd just pick up a bulletcam kit on its own (inc mic, powersupply) and then use my DV camera to record...
http://www.helmetcamera.com.au/
http://www.dogcamsport.co.uk/DogcamPro.htm
12volt
and sd card memory.
Something like that would be sweet for me. What is a set up like that worth? Or is it cheaper to get a digi cam?
yeah no worried big fella. do you need the DV cam to go with it too? I don't need it atm. and in my 32 on the cage it's wide enough to see steering, and gear changes. :)
seriously think about switching to a DV cam mate. HDD cams and DVD cams are no good for track use. the constant vibration and knocks and bumps will destroy your camera HD. DV cam is the cheapest most reliable option for motorsport, unless you look at solid state memory like the SD of CF AV recorders (like the one trent posted) that take input from a small external camera.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
