[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
Hmm... Just on 400 KW at the treads Via a 77.7 mm crank... now you got me worried!!!!!
lol, yeah, I'm unsure on the correct calculation method, anyone wish to clarify? but thinking about it basically (all my brain allows lol) is that the shaft will see more torque than the engine output.... :)
Mick
but your still only getting half the torque going through the rear wheels as up to 50% of the torque will be transferred through the front shaft on launch which would really be the only situation where you would have a chance of breaking it
Great news,
I dont have a computer monitor at home at the moment so havnt been able to keep in touch with it all.
but i get to work this morning and no emails at all. but glad its all sorted now. i still find it strange that they say he didnt have the addresses when Michael was the last to add and one of the first to receive..
Anyway Andrew(Merli) I am still waiting to hear back about yours. but i figure it is going to be yours. want to arrange a time and a place?
Cheers
Andrew
If you don't think that we'll feel any difference from the 9kg carbon shaft, then why do you want to buy a 9kg chromoly one? :)
I too am in two minds about the 2000ft/lb shaft... Reading back through the thread, we were told it would be "about 3 lbs" heavier... Even then, I should have gone with the lighter one, since I'm not making that much power... <sigh>
the reason I'll be switching because it's about the same money as replacing the centre bearing. far better to have a one peice shaft which is lighter than stock and never have to mess with the centre bearing again. and sure some small weight saving is good (even if not immediately noticed by the driver). but I don't think it 12kg-9kg would be felt. but checking other sources people say the 32 GTR shaft weighs 14kg, so 5kg saving could be a different story. :ermm:
don't get me wrong, the carbon shaft is still the awesome. and I do half wish I'd bought one! and they really were a steal at the prices you guys paid. especially for the light 1000 ones. that would have been the pick for me, cheapest and lightest. :( though Mick has good point about torque multiplication which you'd have to consider for the guys with serious power.
whilst some torque is sent to the front, on that initial moment that the clutch is dropped at potentially 8000rpm, wouldnt the main shaft take 100% of the torque for that instant, and moreso if your running on some sticky DR's? and it is only that tiny fraction of a second of high load that would do the damage id think?
Certainly for the majority the lighter shaft will reap the most benefit, but either way the bigger shaft will no doubt be a good piece of mind to the guys running or planning to run big power and launches.
Andrew, we'll setup a time & place when you've confirmed that it's my shaft...
So has anyone else, other than GTR13 with his R34 actually fitted these yet? I will not be happy if after this whole debacle, the shafts don't fit properly, and I'm going to have to f&$k around with getting a custom spacer machined up.
This 'not fitting right' deal might have something to do with not having the correct serial number, assigned to you, so untill, and if everyone can spare a minute looking up their shaft serial numbers and comparing them to the paperwork, we might never know what we have against what we should have. My setup is: R32 gtr with a 6sp Holinger and my numbers dont match. I have not attempted to install the shaft yet but would not be surprised if it wont fit.
No worries, i didnt get a chance to try to fit this weekend, i may have to wait till i can get it on a hoist as i have all under bracing that needs removing before i fit.
Well a LOT of luck for me. Looks like I came back just in time, and chased up the 'old' address.
There were 3 delivery attempts by fedex but since that address has been vacant for some time now no one was there to get it. So i call up fedex and they tell me how lucky i am, as they were going to send it back to sender TODAY. so one day more and it would of been more mess!
Finally i have the thing sitting in front of me, serial numbers on shaft and invoice matching too.
i have 0708048
ill go measure up
so ive got an 840mm carbon section and a 1120mm total, can anyone confirm the correct length for the 2000model 33 shaft?
Edited by SLY33
Well mines supposed to be for a GTR33 95model and going on SLY's measurements mine is 835mm for the carbon and 1120mm total length..
Supposed to be 2000ft/lb shaft.
At least our total lengths are the same..
It could be at my house Andrew, i only have Keith from W.a without his on the 2000hp 32gtr list.
want to arrange a time and a place to get it?
Edited by Angus Smart
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
