  • Replies 96
Still good for one track day at least. Not rated in ks but laps if anything. Once warmed up slicks are nice and sticky and not as frustrating not being able to turn in or accelerate as much as you would like on corners.
By the way for those participating and having lunch we have a couple of cases of the mighty V as well as other drinks. Yes we know the Skyline guys live on the stuff. But lets not make it a V topic just letting you know DON'T pannick it will be there.
Maybe my zed might go faster if I threw some down my throat.
Originally posted by benm
Slicks eh, interesting !
How cheap and how used ? (As in approx how many km or laps would I get at EC with no drifting doing 2:00 laptimes?).
To get RE540 Semi-slicks in 225/60/15 it was going to be like $290ea.
:bahaha: Benm gets the trackday bug and goes straight for cheater tyres!
See y'all there, cant wait to give the gibson car a good run around :P
I'll even go easy on your Z john, since you are the host :D
trackday bug yes, cheater no.
Once i have my brakes sorted out (got some proper fluid now and also need to learn how to use them better) im expecting about 3-4sec a lap quicker just from that. With a better set of tyres im hoping for another 5+ sec quicker.
Won't be long and i'll be under 2mins at EC, probably early next year.
John.... the last two UAS days have been a week after a Motoconcepts day and the old girl has not been able to back up after the day at Eastern.....blown this/hammered that:(
Oh well there is always next year at Wakefield! Ill still be along to spectate and enjoy the day.
Thanks for putting on these days , and supporting the scene.;)
I have a mate who wants to come have a look, he has two sons (5 & 10 YO or something like that). IS it OK to bring kids ? I'd imagine it would be OK behind the fence but not in the pits.. I haven't been to Oran for ages so I can't recall what it's like there.
Super keen to come but am a little uneducated on how to get to Oran Park!! Was wondering if anyone from around my area (Chatswood) was going....*cough* Brendan, Dino, Nick etc *cough* and if i could follow them out there!!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
