spotted a pearl white V35 at the end of M4 parramatta road yesterday morning. Asian chika driver.
also spotted a bluish V35 along James ruse drive crossing Great western Hwy.. was raining hard couldnt see properly
spotted a guy driving a silver v35 stock looking at orange grove on Thursday
he saw my car and proceeded to drive like an absolute cock head
then, as i tried to say hello, gave me attitude and left
wtf is the world coming to?
coming to.... an end.. all moral flush down the toilet..
He had probably just stolen it!!!!!!
I see a few V35s a week going to Epping from city. No one seems to wave these days... In the beginning, everyone waved at each other.
Dam if i seen another V35 i would be hanging out the window waving like crazy, beeping the horn, flashing the lights and yelling "HEY LOVE YOUR CAR" :P
I flash, beep and wave at every V35 Isee, but as yet, nobody has reciprocated.
Speaking of which, I keep seeing 2 black examples: 1 is always parked at the industrial estate at Ernest, and the other is always on/turning onto Southport-Nerang Rd in Ashmore. It has personalised plac=tes: can't remember whatv they say, but they are gold text on black background...
Ok I've seen at least 9 different Vs over 3 days on the same street .. Quay Street at UTS... 5 silvers.. 2 blues.. 1 black.. 1 red.. every colour of the v35 rainbow...Someone here has to be one of them
On of 2 blue ones, might be me.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
