OK, this isn't a joke, I honestly have NFI what this is, what it does or how it works.
I have found one on e-bay exactly the same, but a different brand, but the ad still doesn't say exactly what the hell it is :(
http://cgi.ebay.com.my/M5-Micro-Kompressor...1QQcmdZViewItem
Ideas anyone?
https://www.sau.com.au/forums/topic/210285-todays-mystery-object/
with a claim like "Saves fuel up 5% to 35%" i'd say its a box full of lies and bullshit
Thanks for that... :(
I have a feeling that it is along those lines, but I still want to know wtf is does and how it is supposed to do it...
thats got me totally stuffed how it could possibly do anything. Its got one air pressure fitting in the side and the guage but the brass bit on the bottom looks like an air exhaust port..like a silencer...I dont understand how this gadget can supposedly go onto any car and make the differences it does....
Annnd on that note, I would just like to qualify that I did NOT buy this, and do not own it (or desire to) I just want to know what the hell it is and what it is supposed to do.
hmm obviously ties into vacuum lines and alters airpressure...? might be a way of tricking computer to make it run leaner...?
Kompressor... beats me. Cool mercedes.
That sounds plausible but I don't think it would be tricking the ecu (unless it had a factory map sensor), more like vacuum leak before fuel reg to lower pressure and lean it out.
Sounds dodgy, buy it Dale! :)
I'd have to say you shove the thing into your ...um... ear and it feeds you a steady stream of BS. Looks like they have grabbed an old vaccuum guage,welded some air fittings to it, and stolen a bunch of gimmick stuff/advertising from other products/companies. My bet is it's supposed to do nothing at all except rip you off. You'd better buy all they have rooster. Then again it looks kinda like a chew toy for a staffy, might take mine more than 5 seconds to destroy it....
I discovered some information about this:
****Air Charger (Base on Mechanical)****
The system is a set of the component that will force the air drawn into the cylinder, and of cause by forcing the air, this will directly increase the air pressure and the air will drawn more and more faster. Then, during the cylinder valve is open, the air and the fuel mixture will rapidly fill in the space inside the cylinder in a high pressure. Due to this, more quantity of the air is allowed inside the cylinder.
An internal combustion engine can be view as a sophisticated air pump. Air is drawn into a cylinder along with a proportional amount of fuel. The mixture is compressed, ignited and expelled. The exploding air and fuel mixture is the source of the engine's power. The amount of power an engine makes is generally directly proportional to the engine's displacement. Displacement describes the cumulative volume of all the engine's cylinder. The bigger the engine's displacement, the higher the power the engine produces.
The system force more air and fuel into a cylinder than it could take in under atmospheric conditions. The more fuel and air in a cylinder, when ignited, the more powerful the resulting explosion. If you force 50% more air into a 3.2 liter engine it performs like 4.8 liter engine!
Instruction:
How to fix the micro kompressor on your vehicle:
1, Check original rpm before installing Micro Kompressor.(Ensure air-condition is on off mode).
2, Switch off the car engine.
3, Remove the hose connection from manifold supply air inlet.
4, Reconnect the hose with “ T ” join and link it to the additional hose provided.
5, Preferably fit the unit away from hear area.
6, Shorter hose would be much advantageous.
7, Place the unit slanting position at the angle ranging 15 to 45 degree gravity manitude.
8, Air vent-screw should be tighten up before switch on the car engine.
9, Start car engine and wait for a few minutes
10, Counter turning by adjusting the air vent-screw to obtain original rpm reading or engine become stable.
11, Instruction diagram printed on the box.
WTF? Talk about Engrish!! Thanks heaps for the info dude. Any chance of a link to your source? I want to know exactly how this thing does what it claims, because I still don't believe it.
ahaha - it sounds almost like one of those nitro RC booster bottles
it seems almost to store an air fuel/mixture on one pulse, and the next pulse it is sucked out, boosting the engine (albiet a pooftenth) and the next pulse re-charging again
Link here:
http://www.turbulence.es/foro/index.php?topic=560.1050
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
