OK people the engine is finally in!
The fuel rail,fuel lines,injectors,coils,pumps,power steering and lines are all done.
All of the harnesses,plugs and connections are done also.
Just have to do the vacuum lines and move a few things about. Aswell as the gearbox and tailshaft.
Had the engine in and out 3 times as the external oil drain gave a bit of grief clearance wise. A small patch of the firewall was "massaged" back an inch and then painted. Turned out really good in the end.
Pics will be up next week :domokun:
EDIT: BRIDE seat is in too.Man that thing is snug :O
AWESOME!
i was hoping you'd get it in. good work dave. I spent the whole day on my brakes lol.
cya soon
Was about to give you a call on sat night Jeff. I needed an extra body to help me lift the gearbox in. But the garage floor was friggin' cold and threw in the towel :)
Thursday,Friday ill have it all finished........WOW cant believe i just typed that,the car has been off the road now for 5 months.
Pics will be up next week :)
NICE! Been keeping a real eye on this thread, will help me decide on whether to keep the GT30R/RB25 combination :P How hard are you going to push the tune when you do it? It'd be rude not to crack the 20psi mark!
NICE! Been keeping a real eye on this thread, will help me decide on whether to keep the GT30R/RB25 combination :) How hard are you going to push the tune when you do it? It'd be rude not to crack the 20psi mark!
14psi for the run in tune,and 20-22psi for the full tune.
22psi is alot of boost to run on pump fuel. See how the motor likes it on the day,though i would like to see how much i can squeeze out of the turbo before we settle on a good reliable tune/boost setting.
Ahh yeah sounds like a good idea, on both levels :) 22psi is pretty much where I'd be going high boost as well. 20-22psi is high but really a safe limit for pump gas, so long as you have a good tuner etc - I know people running way more than that, but they are certifiable.
Really looking forward to seeing the results on 20-22psi, it should go very very well.
Edited by Lithium
Ahh yeah sounds like a good idea, on both levels :) 22psi is pretty much where I'd be going high boost as well. 20-22psi is high but really a safe limit for pump gas, so long as you have a good tuner etc. More competitive people I know are running as high as 28-29psi on pump gas (98RON) and have been for some time without issue.
29psi with a GT30R?
29psi with a GT30R?
DOH I was a bit slow on editing it, I was just talking about boost level in general. No, not on a GT30R - there's probably no point going over 22psi on your setup... sounds like just the right level :)
Edited by Lithium
Well after 2 days of trying to get the gearbox on,its finally on.
But i had to remove all of my hard work and pull the motor out again!!! :D
For some silly reason the input shaft wasnt going in properly.The splines would align but stop about 10mm of being flush with the block.
So the decision was made to pull the motor out....again....for the 4th time.
Off the car the input shaft wasnt going in properly, so i removed the clutch,had alook then tried to align the clutch plate as straight as i could.
Clutch back on still didnt line up. As i was about to give up i just gave it one more half assed attempt and donk! Slid straight in.
Which kind of pissed me off because i didnt do anything different to what i had been doing for the past 11ty billion hours.
So then the box and engine went in together,which was very stressful.
But anyway the engine and trans are in,with all the ancillaries. Tail shaft will go on tomorrow.
So a week or two from now ill be getting all the piping done and she'll be ready for a drink of oil and the install of the Haltech.
Then fired up :banana:
should instal the haltech wiring now while your loom is out, i got a LTX12 that im installing before i put the motor in, however im also getting the engine tuned and run in before it gets into the car lol.
acually, when you put the engine back in with the gearbox attached, did you have any clearence issues with the oil return 90degree bend comming from the back of the head?? just thought about it since you have to have more of a angle to get the box in... unless you got a high engine crane and jack the car up a bit.
Safe boost pressures come down to if your within your turbo's efficency range, and if your tuner can tune the car accordingly. Highest boosts ive seen and experienced on 98 octane was was 30lb on a 2jz making a little over 500rwhp (GT35R), and a RB3025 with 32lb making 625rwhp(custom T51 varient). 4th gear traction loss at 180K's, yes.
If your engine has the forged pistons and rods to support at least 100hp per cylinder whats holding you back...
Edited by Vspec R33
Im buying a flying lead for the Haltech so its plug and play.The oil drain was a bit an issue but we managed in the end.
We will see how it goes when the engine is run in,i wouldnt like to boost it over 22 psi as my comp ratio is slightly higher than standard.
The GT3076R when I looked for and chose one looked like it'd be best used at around 22psi on a built RB25DET so there isn't a huge amount of use for it over that. Its a nice not overly laggy turbo on an RB25 so with 22psi there should be a huge fat power delivery, it'll be wicked for a road car that can do drag and track. Just because the engine CAN make 100hp/cyl doesn't mean you are obliged to - it just adds one part of the equation to get what you want out of it.
Highest power pump gas/power per litre car I've been in was a still 2litre EVO 2 running a .82a/r GT3582R running ~2bar of boost putting down just under 500whp (125whp/cyl), way faster than any daily driveable 4cyl street car should be.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
