The GT3076R when I looked for and chose one looked like it'd be best used at around 22psi on a built RB25DET so there isn't a huge amount of use for it over that. Its a nice not overly laggy turbo on an RB25 so with 22psi there should be a huge fat power delivery, it'll be wicked for a road car that can do drag and track. Just because the engine CAN make 100hp/cyl doesn't mean you are obliged to - it just adds one part of the equation to get what you want out of it.
Highest power pump gas/power per litre car I've been in was a still 2litre EVO 2 running a .82a/r GT3582R running ~2bar of boost putting down just under 500whp (125whp/cyl), way faster than any daily driveable 4cyl street car should be.
Yeah i agree with you about having a drivable car and not necessarily having to run at the 100hp per cylinder mark. I figure most car enthusiests that do get to own a car that is stupidly over powered proably in the end gets rid of it and trades down to something with a more practical power range.
Personally i hate big turbo cars. Lag, followed by the lack of traction that follows. A problem caused by running a turbo so big that its flow is in the middle of its efficency range when the engine is at its redline. I much prefer having a car thats matched so that in the middle of its rev range, the turbo's are pumping at the middle of their efficency range as well.
And dam! 500rwhp in an evo! Those poor tyres... :D
AWHP EVO, not rwhp haha - and it put its power down extremely well, its an absolute monster on a race track.
I don't mind big turbos, they have their place - I just hate it when people under or oversize their turbo for their setup. For example, that evo running 280degree cams and revving to >8000rpm on 29psi is running not overly short of the choke line of the compressor map at redline but it is a huge turbo on a small motor. On the other hand I reckon a lot of people on SAU using GT-RS are running them beyond their efficiency (both hot and cold side) and I'd hate to imagine what life would be in the exhaust manifold of those things.
Anyway, sorry to thread jack Nytsky - I find it hard to avoid this thread as I am amping to see how your car goes, when do you expect it to hit the dyno? :down:
(edit after seeing Cube's response) Yes, you hurry up too ;) I eagerly await both of your results and impression to help decide the fate of mine haha
Edited by Lithium
I ran a GT3076R .82 on my stock RB25 for 18 months, it was nice once you were moving, 1st gear and most of second was a nightmare because the turbo just hit so hard it would just wheel spin all over the place, even in 3rd it was a hand full coming into boost because of how hard it hit, more like a light switch, I then switched to a GT35R .82 and it was far better, much easier and more fun to drive, I can change gears at 5000rpm in 2nd into 3rd and stay at 1bar (my low boost), My customers RB25 is running a T04z and I personaly find that even easier to drive on the street in lower boost levels than the GT35 purely because its much smoother and more progressive coming into boost and having a 4000rpm band of 1.5bar makes it just as easy to drive as my GT35R (besides that it KILLS me in a straight line) I also find around a track that big turbo is also a lot easier to drive because you can give it a lot more pedal in and coming out of a corner and you can feel it starting to power up vs the smaller turbo's where they just hit and your left going sideways.
Just my 2c on why somtimes larger turbo's can actualy make it easier to drive.
lol you sooks
I run a GT3076 with a 0.63 rear, and it makes 314rwkw, and 720nm of torque.
Drives like a V8. Curve was exactly the same as my mates 300rwkw LS1, except he had a bit more torque under 3,000rpm.
I wish mine was like that, I would get to 3300rpm odd and BANG 1.5bar, tire smoke and drama, probably why I only managed an 11.6 with that turbo, the pull away was a nightmare almost always a 2.1 or 2.2 60ft. I think with the weight of your R33 vs my S14 also would make it a lot more noticible for me, I am now doing 1.8's and 1.9's with the GT35, high 10 here we come.
if its that bad maybe try a good boost controller, i know my avcr is able to be programmed for each gear and in 1000rpm increments, using one of those will get you the full power of the 3076 up top but more controllable down low.
Maybe it was the setup? Were you running an aftermarket exhaust manifold?
I run the GT3076r .82 IW on the RB30DET. That pretty much makes a psi straight off idle then ~5psi at 2000rpm; 9psi at 2500rpm and then 19psi odd at 3100rpm.
Boost is fairly tractable with simply less throttle input; or I just grab the next gear and let the torque lug it out. :ermm:
Yeah it was an aftermarket top mount with 38mm tial, could happily run .8bar, but even with .8 it hit had with the Profec b set to zero everything low boost it would hit hard and would try to come in very fast around a track, then again my "coming in hard" could be different to your coming in hard, I stuck that turbo on an SR20 and it was a joy, came in beautifuly! even ran faster than me at the same boost :-(
Anyway, sorry to thread jack Nytsky - I find it hard to avoid this thread as I am amping to see how your car goes, when do you expect it to hit the dyno? :ermm:
(edit after seeing Cube's response) Yes, you hurry up too :) I eagerly await both of your results and impression to help decide the fate of mine haha
Will be going to the exhaust shop in a week or two,then its off to the tuners so it will be on the road in a month id say.
On a side note my throttle cable is now too short for the plenum and trottle adaptor.No matter how i run it,it wont work.There must be people running the same setup as me who have got around this problem. Any suggestions??
Z32 throttle cable
did you have to roll the gaurds to get the rears to clear?
what size tyres do you run?
Nope,did not roll the guards.The offset in the rear is +42,and 265 wide tyres. The tyre sits about 10mm away from the coilover.
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
