Looks fantastic Dave! I'm going to have to cut the hole for the VCT on the cam gear cover aswell, yours turned out better than i thought. Did you retain the RB25 backing plate or did you use a RB26 one?
Edited by PM-R33
Still has the 25 backing plate, but you will need to shave the top corners a little for them to fit inside the cover.
Ah ok sweet. Really didn't want to take the timing belt off just to change the backing plate haha.
heat tape on the cam cover blends into the ceramic well, took me a while to spot it.
setup looks neat dude, got any shots of where you connected the braid to the factory lines and life pump/return etc?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
