I think they all say that, same with the stainless braided, only one suitable is the teflon and unless I win the lottery I cant see that happening!
what should I use?
ended up getting teflon hose and fittings from this guy
http://stores.shop.ebay.com.au/Torques-U-K__W0QQ_armrsZ1
happy with result, back yard special but its ok, main thing is she's nice and rich, not sure if it's safe running 2 bar tho!!!!
how is the car going with the new 3582, im just finishing up my 26/30 build with this turbo and would be interested to know if this turbo will give me 550hp at the wheels
oh and how much to get my comp cover slotted cos i would really like to have that 51r spool noise
if you dont end up with atleast 550hp atw with that combo, your not trying hard enough haha
thats from my evo with a 2.2 stroker and gt35 .63 rear housing..
sounds good then, should be done buy next month and have it down brissy for powercruise, providing all goes well and i can pay for the vipec and redlines oils needed lol
oh and my 3582r has the 1.06 rear
Edited by blockasR32
Nice one Adrian. Your pumps are probably as loud as mine ;)
Does anyone know if i can still retain VCT with Tomei Procams? 270/10.25mm? IN/EX
More to come guys.....stay tuned :sick:
I know you cant on the 33 head dave and i dont think you can on the neo either. dont quote me on that but i am quite sure its the case.
Hmmm i really dont want to lose the VCT.
What is the biggest i can go with the intake cam?
Is say a 270/9.5mm IN 270/10.25mm EX doable?
Or
260/9.5mm IN 270/10.25mm EX doable?
Or
Do i just go the 270/10.25mm IN/EX then get one of those Greddy adjustable inlet cam gears?
I need some options.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
