Fark. Whats going on with your old motor?
Yes, the 25 has been sold to another forum member.
I'm confused. So what is this new motor?
New bottom end is a RB30 with:
NITTO Pistons
NITTO Rods
NITTO Headgasket
ACL Race Bearings
ARP Head and Mains
Prepped Crank
Moroso External Oil Pump
Big Sump
Built by Paul from Red R Racing.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
