Well after 2 solid late nights the bottom end has been assembled :)
A last minute decision was made and the 25 head will be put back on but will be slightly played with porting wise, just to get the car back and get it roadworthy again before the rego runs out.
The "Red R Secret spec head" :woot: will go on at a later date.
Pics of the ASR race sump will be up in a week or 2.
Going to get it engineered, emissions the whole nine yards.
I have to get a quieter exhaust made first though. How do you make a 4inch exhaust flow 450+rwkw and be around the 90db range? That is the question.
Start with 2 center mufflers and twin 2 1/2inch rear section.
Check these out:
http://cgi.ebay.com/ebaymotors/BULLIT-4-in...sQ5fAccessories
Would they suppress the noise though?
Being 4" makes it hard any muffler you get off the shelf is going to have been designed for a truck/generic truck uses unless its custom, though you need some size to the mufflers to get any real DB reduction out of them. I would/will be (when i get to it) going as big a middle muffler as you can fit (something oval shaped, keeping in mind 10cm ground clearance so it needs to hug the body pretty well) and a custom muffler for the rear thats as large as they can make fit in the space.
If you go overkill from the start you can always make it louder later on but having to modify it multiple times because it isnt quiet enough gets expensive.
NSW is harder than ACT as you need to be 91db or less from idle to 4500rpm (or what ever they test to), ACT you just need to be 91 or less at the test RPM.
have you chosen a Turbo setup yet?
what diff ratios are you going to run and what gearbox?
running 4.3 diff will help alot when it comes to response especially out of corners,
The supra in the vid seems to have short gears which helps minimise lag into the next gear.
oh and let me know when its done im definately coming to eastern creek when your car is done
Titan is on the money, Dave you need to fit two of the largest oval shaped straight through items you can fit. Being in the exhaust game I might be able to assist with something that will suit off the shelf. Otherwise a custom hand packed can and tube similar to what Racepace offers may be your only, but more expensive option.
I was pricing up 4inch pipe last night.
$176US for a 4ft straight tube of stainless delivered.
But buy 3 of them and its $675??? Figure that one out.
$120US for a 4ft straight tube of mild steel delivered.
Hey,
The short answer? I think you can get "close" but that won't cut it for emissions testing.
Depends on whether you only want to pass the test; or whether you need to be 100% compliant 100% of the time, and also on whether you want to run your turbo to within an inch of its life
(e.g you might be able to make the power on a more-restrictive system by leaning harder on the turbo).
If pass-the-test - build a system as close to legal as you can:
6" metal cat + 4" stainless perf + wrapped in stainless steel wool + fibreglass + stainless can x 2 (2 large custom mufflers) got me down to 93dB.
They were made as large as would fit in the available space.
Then do whatever you need to pass the test (e.g. plate-with-holes-as-gasket; made out of cardboard so you don't need to violate your cert by removing it :ermm:
Provided you're close-to-legal (i.e. within a couple of dB) you should be fine.
If 100% compliance required, I think you'll have to size back your exhaust and flow demands or accept a shorter turbo life.
Also, twin 2.5" is roughly equivalent to 3.5" (not 4"); so you might want to go 3.5" to twin 2.5"; or 4" to twin 3"
I'd guess those mufflers will either flow well (small diamond) or reduce noise levels (big diamond) but I doubt they will do both.
I don't think they have enough volume. I haven't measured them, of course. Any muffling is going to hurt performance some.
I'll be interested to see your results; as I think my last cooler-pipe-off-flame destroyed the packing in both my mufflers.
Cheers,
Saliya
Dave, my whole exhaust system is purely custom, can have it made to any length and shape etc with the mufflers.
The guy who does it is a family friend, to build my exhaust I had to take the car there, jack it all up, and he actually went under it and measure all sorts of things to get the mufflers the perfect lengths etc to fit.
You can fit some MASSIVE mufflers in there, including before the catalytic converter.
PM me if you want me to try T-up a time/day to have a lot
Hi Matt, are the mufflers custom or a stock item that can be ordered. My business (Lillford Exhaust) are going to try and sort something out for Dave as his car is at Red R Racing here in Newcastle and it would be nice to have the car fully complete before it returns to Sydney.
Ill be ringing suppliers for something suitable tomorrow but if you can give me the heads up it may save some time.
Thanks in advance
Dave
Edited by blitzxtr
Twin 3 inch would be a lot easier and look less like a truck exhaust. :)
The worry will be when the emissions test comes up so low, they will want to know why...
my brother has an apexi n1 which is 3" straight thru, sounds completely different to a single pipe setup & much louder :)
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
