Dave all i can say is wow awesome thread mate and seeing you motor and car in the flesh yesterday i was like god damn it i want more money lol. I was seing paul about getting a very tame build in comparison on my gtr still should be good for 350 + kw.
awesome stuff man keep it coming
Edited by gtr_scottie
Not yet they dont. That cooler has been in development for 2 years now, not sure if they will ever bring it out.
I bought a 100mm Tube and Fin cooler when i was at Jambo on the weekend so all is well. :blink:
Paul has stripped my engine bay and painted it. He has also sent all brackets and some bolts to get zinc plated.
The ASR Race Sump arrived on Monday, will post pics up soon. I also ordered a set of light weight underdrive pulleys for the alt and water pump, should get to Pauls next week for him to put the finishing touches on the bottom end.
ive got one on my car, got it a few years ago, http://www.performance-wise.com/page43.htm about halfway down the page but yeh they are under re-development and they are aparently 94mm now, im pretty sure they were 96 mm before, not that 2mm will make much difference
Edited by s13_Skyline_inside
Small update,
Most of the zinc plating has been finished.
All wiring has either been hidden or re-worked.
Head will be sent to the machinist to get stripped, ported and holes enlarged to accommodate the thicker headstuds.
Should be able to get some pics up soon.
No not a showcar. Just a very nice, clean one.
The engine bay is starting to put the rest of the car to shame, so i guess it will have to be resprayed eventually.
Paul has pulled out all stops this time round and wants to make sure everything that can be done is done.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
