  • 5 weeks later...
Been a while so here is an update.
Double checked piston to valve over the weekend to get the headgasket thickness.
A 1.2mm Nitto gasket has been ordered which will give us a 9.0:1 CR :)
Waiting on a billet flywheel from the states, so engine should go in this week.
Paul did a great job with the engine mounts so it will hardly look like there is a RB30 in there :D
Mufflers came in so most of the exhaust fab will start this week.
Ill be heading up to Pauls next week to have the first look since the bay was painted etc.
Turning key on it very soon :)
Paul did a great job with the engine mounts so it will hardly look like there is a RB30 in there :)
Turning key on it very soon :D
and a very nice set of mufflers they are!!
Edited by jangles
Sorry Dave, looks like i will end up beating you at this rate haha
Modified twin turbo pipe should arrive tomorrow, ARC air filters still on their way (was going to go back to pods, but found filters for a price i couldnt say no to), exhaust is all just waiting to be put together and then its all systems go
Ok you win.
Even when this engine is in and running we still have another head here we are working on.
The HKS cams in the current head are great but need that big ass lumpy note for Powercruise :D
Tomei 270s :D
Ok you win.
Tomei 270s :D
setup antilag, guilt-toy was asked if his car had a V8 in it a few times with it running and he was on stock cams.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
