I had the same problem with my car, exhaust tone was nice but after driving it for 20min u get over it pretty quickly (its a sign of old age, I like to call it maturity lol)
Besides that, when the exhaust db drops, u get to hear more engine noise which is a major plus.
Wont be making the drag day, still need to make changes for it to be road worthy. As the car has been pulled apart and off the road for so long, Adam suggested that the car as a whole needs a few K's put on it just to see if there is anything that needs attention.
So far 200rwkw@10psi 5000rpm. Makes more power and torque everywhere. Feels strong.
Ordered my new plates too :)
RB25/30
Ported head
HKS 256/264 cams
Tomei springs
Nitto headgasket
Nitto/JE pistons
Nitto I beam rods
Block mods
etc etc etc
GT35R.82
6boost manifold
4inch dump
4inch exhaust
I hope the rear housing will be big enough.
RB25/30
Ported head
HKS 256/264 cams
Tomei springs
Nitto headgasket
Nitto/JE pistons
Nitto I beam rods
Block mods
etc etc etc
GT35R.82
6boost manifold
4inch dump
4inch exhaust
Cheers, and I am sure it will be fine... for some reason I thought you were going GTX
Ffs dont waste your time and money with the .82 housing Dave. It will only end in tears.
At the very least use a 1.06 housing and even then dont tune it without egt sensors.
You setup is almost a mirror of mine and the 33 racer car. I wont tell you how any 35r's came to grief between the 2 engines before we woke up. Using the .82 is like f**king for virginity, You wont get the desired result.
What Noel said mate! :)
But if you do manage over 400 with the .82 ill be impressed, especially if the backpressure isnt stupid and you can keep egts below 800c and stop the turbo from shitting itself the first time you go do a track day.
he did manage to pull over 400 on the RB25. topped out at 429kw from memory?
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
