I had the same problem with my car, exhaust tone was nice but after driving it for 20min u get over it pretty quickly (its a sign of old age, I like to call it maturity lol)
Besides that, when the exhaust db drops, u get to hear more engine noise which is a major plus.
Wont be making the drag day, still need to make changes for it to be road worthy. As the car has been pulled apart and off the road for so long, Adam suggested that the car as a whole needs a few K's put on it just to see if there is anything that needs attention.
So far 200rwkw@10psi 5000rpm. Makes more power and torque everywhere. Feels strong.
Ordered my new plates too :)
RB25/30
Ported head
HKS 256/264 cams
Tomei springs
Nitto headgasket
Nitto/JE pistons
Nitto I beam rods
Block mods
etc etc etc
GT35R.82
6boost manifold
4inch dump
4inch exhaust
I hope the rear housing will be big enough.
RB25/30
Ported head
HKS 256/264 cams
Tomei springs
Nitto headgasket
Nitto/JE pistons
Nitto I beam rods
Block mods
etc etc etc
GT35R.82
6boost manifold
4inch dump
4inch exhaust
Cheers, and I am sure it will be fine... for some reason I thought you were going GTX
Ffs dont waste your time and money with the .82 housing Dave. It will only end in tears.
At the very least use a 1.06 housing and even then dont tune it without egt sensors.
You setup is almost a mirror of mine and the 33 racer car. I wont tell you how any 35r's came to grief between the 2 engines before we woke up. Using the .82 is like f**king for virginity, You wont get the desired result.
What Noel said mate! :)
But if you do manage over 400 with the .82 ill be impressed, especially if the backpressure isnt stupid and you can keep egts below 800c and stop the turbo from shitting itself the first time you go do a track day.
he did manage to pull over 400 on the RB25. topped out at 429kw from memory?
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
