I've got an auto R33 gtst-series 1 that I got recently, and my fuel consumption is about 280-300 kms per full tank.
So from what I've read so far, changing the O2 sensor, plugs, might help. Also I didnt get what the ecu + remap + piggy back does and would it cost too much?
thanks
  • Replies 74
Posted Images
off the bat, just replace the O2 sensor (they're liek $80.00 new delivered from KUDOS), and give the AFM a clean with carby cleaner.. stock air box helps as well, and check for leaks.
nothing wrong with stock ecu if you don't plan to run many mods
If you have a PFC make sure the O2 sensor is turned on.
my tuner left mine off and was wondering why i would get 17-18L per 100km just cruising around.
It dropped down to 13L per 100 once on. hopefully get it a little lower once my tune is touched up today by a different tuner :cool:
If you have a number of mods it can cause the stock ecu to not be ideal for the modified setup. One thing is the ecu can go into rich and retard mode which means it adds extra fuel and takes out timing. This is more under power though but as you can see will worsen your fuel economy.
Custom tuning can also further optimise your afrs for better fuel consumption.
provided it works!
mines permantly disabled and I cruise at 14.7 a/f usually get up to 400km city per tank of enthusiastic driving at 1.3bar
but saying that, he runs a stock ECU
  • 2 months later...
  • 1 year later...
ah you want to know the secret to getting more Ks from a tank eh?.... I dunno guys should we tell him...
I know it an old thead but I have the secret
How do you all drive your car? It must be Full no, off, Full on, off
LOL funny
I must have the secret, here it is
Buy a hr31 two 2 door skyline. Put in it a RB25det neo in it then a rb26 gearbox and a chrome-moly flywheel, brass button clutch, bosch 040 fuel pump , adjustable fuel regulator , Apex bov, Turbosmart boost controller, Big front mount intercooler, plenum and 68mm XF body, hks cams,Oil cooler and oil filter relocation, micro tech LT-12, TO4 Turbo 69hks inlet wheel and 0.7 housing exhaust , Tial wast gate, 10l sump (for Oil), head std kit (ARP), mean std kit(ARP), commadik head gasket, gates timing balt, N1 oil pump.
and made 350rhp ish on 12psi on pits dyno and If you drive it like a normal person and you get 550ish + out of a tank. Drive like a wanker and you get about 300ish.
WIN WIN WIN ON FUEL
Just switched back to 98 after 18 months or so on E85. (Around 240rwkw)
So far on the first tank i'm up to 320km and about 1/8 of a tank left. There has been very little cruise going on. I would say 80% of the driving has been foot to the floor (very little O2 use).
Very surprised at the economy. I would love to take it for a long country drive to see what is possible but it's too much fun on boost :)
Jimmy
Hey, that's funny. I was just about to head out and buy hr31 two 2 door skyline. Put in it a RB25det neo in it then a rb26 gearbox and a chrome-moly flywheel, brass button clutch, bosch 040 fuel pump , adjustable fuel regulator , Apex bov, Turbosmart boost controller, Big front mount intercooler, plenum and 68mm XF body, hks cams,Oil cooler and oil filter relocation, micro tech LT-12, TO4 Turbo 69hks inlet wheel and 0.7 housing exhaust , Tial wast gate, 10l sump (for Oil), head std kit (ARP), mean std kit(ARP), commadik head gasket, gates timing balt, N1 oil pump.
Hoping to make 350rhp ish on 12psi on pits dyno and If you drive it like a normal person and you get 550ish + out of a tank. Drive like a wanker and you get about 300ish.
i'm a bit out of my legue here but i own a 98 nissan s2 stagea rs4
many problems with fuel economy
albeit many people here have big problems with their setups but i found the best fuel saving device was a boost guage
under vaccume the map uses the o2 sensor and leans out the engine, boost means the ecu runs a default map which is typically rich
in summary when you hear that boost whistle it sounds like this $$$$HHH
keep of boost and you are saving a bundle
Lowest i've seen out of the DE+T is 9.1L/100km. Easy highway driving, with the occasional WOT 3rd/4rd/5th coming into a 100 zone. Fresh plugs, coils, fuel filter, pump, 02 sensor, clean AFM, good oil and good maintenance helps the figure.
State of tune helps also. Plugs, coils, ECU and it's relevant sensors (o2, MAF), low fuel pressure, big tyres, poor alignment, carrying excess weight etc. etc. will all affect economy. Driving style will be a MAJOR factor over all others though...
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
