Spotted CAJFLY I believe - around 12:00am on the Monash Freeway (citybound) nature strip.
Was that you AJ?
Everything alright?
yeh was just sitting there and waiting for 4Door_33GTS (leigh) to get off eastlink. but everything was fine.
I was unintentionally stalking a black R34 4-door in my white R34 4-door :D Followed them into Ringwood Station, then parked behind them, then left at the same time and drove to Burntbridge shops and parked near them again. Just so happened we both needed to go the same places.
:P wasnt me being stalked for once !
i work at coles Xpress on cnr Stud - FntryGully.
wonder if any of u guys go there often, lol if u see my red R33 parked outside remind me to give u a 4cent discount! haha
-H
I use that petrol station every tuesday/wednesday!
Let us know when you work, im out of coles dockets :laugh:
saw a white R33 with a huge wing on cnr of narre cranbourne rd and princes hwy then as i turned into princess hwy at next set of lights saw a marone R33 crossing princes hwy at web st and alson a R34 4 door plates were sumfin like cooli or sumfin. total of 3 skylines in 20 seconds lol
I spotted a nice Black R34 GTST this morning on Jacksons Road infront of the Shell servo about 730... Sounded good :sick:
Also spotted a cool 33 T on the way home on the Monash around 8 near forster..
I was in my White Mazda wagon... team toughness.... :D
SHP-5##
white R33 with gold rims on toorak rd near the intersection of burke (outbound)... he/she gave it a boot past me so i could bask in the splendour of his/her BOV :whistling:
Edited by JMP 82
i dun have a set roaster. im there tontie from midnight till 7.30am. n sunday 6-12
saw a white r33 turning into ftrngully from the service lane around 7.55am, i was in the middle strip trying to go across to the other side.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
