Spotted that Stagea that has some whacky ass alpha numeric rego plate that might say STAGEA... or something.
In Clayton, near CAR-X.
yeah my bro seen that one also, he couldnt work it out, thought it said STARGATE or somthing
also seen a r33, but at first i heard a honda, then realised it was the r33 :S
maron one turning right just after westal off heatherton rd around 745pm
spotted silver r33 with plates CRZY33 , mate you need to relax, big deal its a r33 i see them every where, no need to speed up around a corner just so i can hear your exhaust. its no different to the next r33 i'll see 5mins later
lol.. umm nah u need to relax.. that was my boyfrend driving that day and he was driving normal just like i do...?
he usually drives his silver stagea and u have spotted us before on here... and by the way u of all people should live up to ur number plates anyways :rofl: haha
Spotted Bayside blue R34 GTT and Yellow R34 GTT at Arthur's Seat on Sunday. I was the White R34 Sedan
I was the bayside blue GTT..... also spotted same day a white 33 around Arthur's seat at the top was with a motor bike i think
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
