oh yeah saw 2 r35s. one on punt rd, and the other on latrobe st. driven by different guys but looked the same - both gunmetal grey, both fking hot. couldnt stop smiling after i saw the first one. havent seen them on the road before.
also got overtaken by a black gtr34 vspec on princess hwy/blackburn. sounded sex but couldnt appreciate cos of the idiot in the rex that nearly killed me trying to follow you
spotted mcdee on the monash heading towards pakenham - gave you a thumbs up - was in the yellow jazz dude!
hey Matt, by the time I realised who it was and waved you must have hit the NOS button as all i could see was a blurr
yea that was me :thumbsup: in the 32
got the car back tday.
worst easter
yeah man you live in the same estate as me.. i saw u out there the other day out the front with the car in the garage.. i drove past in the blue WRX
spotted a white r33 gtst on stud road turning onto prinny with ur boot open. tried catching up to tell you but you didnt understand me with your window up lol. hope you realise at some point it was open since it was jumping up and down lol
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
