Spotted white r33 with Sau stickers Green P-plater, cursing along with me along cheltham road last night at about 2a.m
most likely was my car, did u turn off up boundary road near braeside mcdonalds up to cheltenham and i re-met u again on cheltenham road when i passed through dingley haha
Nice clean car u had mate if it was u, my friends wanted me to catch up to u to check it out
lol.. does it make you that angry? have to say, it annoys me too... who do they think they're fooling? :D
agreed matt saw one on a 4 door the other day in springvale as well...just wanted to brick it, where've u bin lately mate aint seen u cruising
yet again i have seen NISR-34 heading down stud road on tuesday night. heard his BOV sounds tuff. also saw a black r34 tonight going down high st n parked at home and saw a white r33 gts-t cruising past glenny maccas. i saw an r34 with LED tail lights like mine but couldnt get a good enuff look to see if it was SAU. i think it was black
+1 i keep seeing you on stud road duno if ur on forums but look slike you might be a new owner? im gonna throw a sau spotted card at your car next time and ill make sure i get it in your window!! haha
Spotted Silver R34 GTR @ knox...didnt see plates, looked really clean!
hey owen that was me! was in mates gtr nur he just got back from racepace... *druel* i thought that was u lol. looks like you finally got ur r34 :) nice one.
Cheers buddy! i turned to my gf and said 'holy f**k, thats a nice GTR' and she said 'how is that one different to yours'....i thought 'OMG'....haha
spotted a white 33 GTR with white wheels turning off fitzroy st intersection on to princess hwy 11:50pm. looked clean. the cops tending to a multi-car collision at the intersection gave it a second look ;)
lol... i drove past there about an hour earlier.... must have been a goodie!
oooooo My first spot wooo!!!! ;)
If it had black te37s it was meeeee!!
Or just after the round about to go down centenary on the service road
Yeah, was parked on the service road. Didn't see the wheels, it was dark :)
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
