Funny how you always see me yet i never see you....maybe you should paint your car fluro pink with bright led's all over it so i can spot you back :)
i'd rather burn my car .....
Spotted AP's s14 at Express Auto Elec on the corner of Fairbank and Prestige
spotted a black r34 around 12ish today turning right into forsyth road jsut off the bridge in hoppers crossing today. beeped at me as i passed. had the window open and scared the shit outta me.
haha that was me mate, I beep at every skyline I pass hoping it's someone here haha.
saw jez in his black mr2 on lower dande road, at intersection of southern rd.
Was in my friends wrx leaving Hella :D
What's that got to do with "Skylines Spotted"? :down:
Nah, I'm just glad to be spotted :huh: They never see me on MR2 forums :D
R32 parked near MSY Cheltenham around 4.45PM yesterday.
White R34 4 door heading eastbound on Canterbury rd around 5PM on Wednesday - azn chick driving - I seem to see her all the time - I only noticed because of the load exhaust - Gotta love the RB sound always grabs my attention....
corner of Blackburn rd exit ramp......Blue R33 with Lenso wheels, SAU sticker......a quick nod of appreciation
( i was in white r34 4 door)
Cheers............good to see SAUers out there
saw both of you in front of me, also at blackburn rd exit. on the way to work.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
