Have'nt washed it for 2 weeks but i did polish it at the same time so still shiny. Had seen that you were from Croydon on the forums, it was only a matter of time before we crossed paths, nice plates too. Do you still have your Enkei's, had the same wheels on my R33, look awesome on white cars.
No I don't. Swapped them for stockies and cash, they were just far too hard to keep clean. That and the design of them even though they were 17's looked small on such a large car. Thanks for the comment about the plates :D
two R34's and a white V35. two curry blokes in each. mad fitment on the r34's. the white r34 put me in my place a bit, but all were doing approx 15ks under the limit most of the time. princes hwy
also stopped at chaddy maccas for a leak and then wandered over to a little meet that was goin on. had a chat to two islander blokes. silver r33, and black r32.
White stock looking R33 GT-R and white R33 4 door at Epping Autobarn around 3PM.
and a few R34 sedans and coupes in the northern suburbs... looks like the R34 is starting to become common, not sure of that's a good thing or not :S
Black R32 GTS/GTST/4 belonging to a guy named Sanjev? or something like that on Saturday morning - evening at strathaird reserve... bomex kit etc.
was meaning to come have a chat with you after the game but by the time i got back from the atm i couldnt find ya
Spotted a black 33 on Ballarto rd with SAU stickers around 6.30, both exchanged nods and smiles.
Were you at the carwash as well?
Clean car you had mate :P
That was me, were you at the car wash with the black 33 i saw on the way in?
Was only a quick wash thats why it only cost me $5 ;)
Edited by W0rp3D
haha yeah...i turned to my gf and said "shit, he plates look like mine"...WESTWD & WANZI lol...
iv'e seen you around before though before i had the 34....in my old pintara...lol
how much you pay for your tail lights??
they were already on the car when it came over here. i was lucky, they are the genuine nismo ones which apparently cost an arm n a leg to get. i saw ur on ur red P's, fkn stay away from knox man pettit is back on the loose and handing out defects left right n centre
Haha yep i was there with my mate in the 33, he is on the forums too.
We were sneaky and used buckets, so it only cost about $5 between both our cars hahaha :P
We were sneaky and used buckets, so it only cost about $5 between both our cars hahaha :3some:
When i can be bothered i go there after 7 and use a bucket and chamoi, couldnt be bothered tonight tho.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
