Are you coming to the official cruise next saturday? :(
I've seen your car so many times on the streets, but I've never seen it close up, I wanna see it :P
Is that the night cruise???... ...I've only just looked at it...
spotted a grey and black r33 at the intersection near the pines
a red r33 @ smiths smash repairers along blackburn road - custom black plates
white r33 s2 driving past me on blackburn road about 30 seconds earlier
and a dark grey r32 parked across from mcdonalds @ crn of blackburn and doncaster road
all yesterday >,< - spotted all of them within 15 mins lol
Spotted a white 34 GTT on Springvale Road near Princes Hwy last night just about 5:55pm.. black (cf?) hood and looked like a GTR front bar and nismo rear bar.
Anyone here? Sorry I just caught a quick glimpse going the opposite direction towards Springvale.
Yea, 24th Oct saturday. From Doncaster to Sunhine to Epping or something like that lol.
dude its in the paying members section for a reason, why not just copy and paste all the details aye ?
hehe....secret fail?
that probs was me, did it have sau stickers and green p's and stock white rims?
spotted a silver s2 33 with gtr spoiler and blackburn rd near the pines
spotted a purple 33 gtr on doncaster rd
spotted a silver s1 33 on renolds rd
spotted a silver s2 33 coming out of shoppingtown. all today
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
