spotted a dark grey r33 gts-t as i was walking past the grand hyatt this morning... he beeps at a taxi driver who was about to pull out in front of him and then skyline guy stuck his finger up at taxi guy :down:
man those taxi driver's cop it hard haha you know it
This morning around 6.30am spotted a very clean R32 GTR plates "SUSGTR" along Bourke road, Camberwell.
Last night around 5PM - White R34 coupe with a flawless finish (factory fresh finish), it was at the BP Thomastown car wash. Had a chat to the guy. He is not part of SAU, it took him 2 years to source the car - not a single dent or scratch. Apparently he is trying to get into the auto detailing industry. Part of a carwash crew in the northern suburbs "Intrigue"
saw silver r33 with gtr spoiler and big exhaust at airport west westfield this afternoon.
no sau sticker - would of parked next to you but i was in daily :banana: lol
Saw the same car in westfield airport west a week ago.i guess that guy works there or something
spotted grey 32 gtr on monashh....washhhh ur carr mannnn if u on here..=]
Could have been me, but I am silver not grey and my car isn't that dirty. Hard to keep a silver daily driver GTR clean when I drive 500kms a week just going to work and home.
Where abouts on the monash?
dickhead in a black R34 cutting laps around eastern beach in geelong at around 9pm, doin burnouts, fishies, etc, bouncing off the limiter and narrowly missing parked cars.
if that was any one on here, couple guys filmed it and got ur rego!
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
