hey mate we are both running rb25s with 3540s. If you ever need some work done call Ben on 0433 270 360 he is a sick engine builder and the best tuner. We have both had our cars on the road for years without a fault or failure, so I HIGHLY recommend him
Nice, the build im about to start will involve a 3582r so i should be up to your speed by the time its done, what else have you guys done internally?
/and/ a black 33 with a low profile rear wing on the ring road greensborough to dalton road... /and/ a silver 34 with no rear wing and body kit on the ring road near tullamarine exit heading west bound. Is there a limit to how many you can spot? :banana:
no, but after a while you'll only bother to post up the cars with sau stickers. there are just too many r33's out there
Spotted a Silver R34 with no rear wing on main road in Eltham this evening
Are you another Eltham member? :down: I don't see that many Skylines around.. except a four door R34 always parked near Autobarn!
I've driven beside a few SAU people before that don't look because I don't have an SAU sticker haha :down: no love :P
Car is done man. Made 280kw on the safe tune :P
Well done man, wouild hav stayed to watch your run, but had a 21st to head off to that night,,how much boost did u run?
burgandy r33 2 cars behind me on middleborough road - you turned onto the eastern freeway and i kept going straight - saw SAU stickers as u turned >,<
Sounds like me,,drive a lot around there..but i dnt have any sau stickers lol
On City Rd, Southbank tonight, spotted what must be the new Ford Falcon GT-R Taxi! The sunlight means it's not as visible in the photo as in real life, but it's certainly a GT-R badge on there :)
Spotted GTS-T Sedan on the Hume Hwy bout 2.30pm heading 2wards ring rd. i was in a big white truck goin da other way
lol no way i saw ya then bud lol
me and my dad were taking his 68 rs camaro (was behind me) to get it rwc at a friends workshop
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
