Is that the new thing now? Yelling spotted when you spot a skyline? lol
well I would have whipped the iPhone out n put it on here but I wasn't that fast lol and I guess only sau people would understand it. Guy was prolly like WTF he yelling bout lol
spotted Basti last night at the glen, with a silver r33 coming out of the carpark behind you.
been a while since my last spot. was my mate in the silver car.
saw VSPEC today. gave him a thumbs up. and got a little bit of rb 26 roar in return :down:
Spotted this arvo on the Maroondah Hwy out near Narbethong heading away from Melbourne a white R33 Gtst
and yesterday morning spotted another white R33 Gtst with SAU stickers on it at Target undercover carpark Ringwood.
on the google website they tell you when the cars are going to go by next - i know they're in Aust atm. My place has been updated in the last 4 months. used to have a beemer in the drive now its empty.
Where exactly can we find out when they're going to go by next?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
