Is that the new thing now? Yelling spotted when you spot a skyline? lol
well I would have whipped the iPhone out n put it on here but I wasn't that fast lol and I guess only sau people would understand it. Guy was prolly like WTF he yelling bout lol
spotted Basti last night at the glen, with a silver r33 coming out of the carpark behind you.
been a while since my last spot. was my mate in the silver car.
saw VSPEC today. gave him a thumbs up. and got a little bit of rb 26 roar in return :down:
Spotted this arvo on the Maroondah Hwy out near Narbethong heading away from Melbourne a white R33 Gtst
and yesterday morning spotted another white R33 Gtst with SAU stickers on it at Target undercover carpark Ringwood.
on the google website they tell you when the cars are going to go by next - i know they're in Aust atm. My place has been updated in the last 4 months. used to have a beemer in the drive now its empty.
Where exactly can we find out when they're going to go by next?
