...because box ain't that common when you're in a Stag... But you will always have enough room to smash box inside a Stag :)
Spotted a black R33 coupe heading south along cheddar road reservoir last night.
lol! pwned..
stuff this haha, who wants to swap for a r34 ?
white r33 on stud rd around 7.45ish. heading away from knox. sau stickers.
blue r34 on dande bypass, had a little play, gave him a thumbs up.
one or two white ceffies. i think two cos they both were stock, maybe different wheels. one at autobarn dande round 3pm and one getting on the monash off stud roun 9pm
Was the blue r34 me on the bypass? I was going to Status Tuning lol.. don't remember seeing any other cars around me at all though so probably not haha.
Spotted a white R33 on Franskton Flinders Rd/Moorooduc Hwy about 1pm-ish today. Custom plates but my mind is blank right now, but it's definitely someone from here coz I knew the plates!
Also spotted a black/dark grey R32 on Greensborough Road about midnight, drove side by side for a while before I turned off. I was driving the S14a beside you. Anyone here? Starting to see a few more Skylines around the area now.
Edited by UnCo
nah wasn't a gtr. we were headin west, and eventually kept going on cheltenham
That could possibly have been me JDR33M with c/f bonnet or Kris with the orange 33 CR33M..can u remember the plate?
na wasent kriss i know his car it was a different kind of orrange.
BTW ppl if u spot a purple/green Charmion colored GTS-T in south eastern suburbs its me :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
