Lol, we should all catch up and have a coffee or 2 at Monash Uni one day :)
By the way fooyoh, is your name Kevin? Did I speak to you the other day? lol
Charles i think i've seen your car at monash before- is sometimes parked on the main strip next to the grph and K building?
There are 2 yellow r34 that i have seen around, one has many stickers on it (and nsw plates) and the other one is pretty clean looking
Why would anyone buy an NA import?!....
btw, I keep seeing a yellow 34 passing my work @ exhibition + lonsdale during middays. GT Wing, black rims with silver lip and a growly zorst.
Has RE Stickers on the sides
You work at Telstra don't you?
I see it parked in front of the Hotel across my work (Telstra) every few days.
Haha yeah that'd be me , I normally park on Sir John Monash Drive.
And yes, there are 2 yellow R34's around Monash, one is mine, the "pretty clean looking" one :D
I first thought that the other one has NSW plates, but it turns out to be VIC plates with yellow background LOL, maybe I should stick a couple of spotted cards on his car xD
QUOTE (gwin @ 4 May 2010, 01:35 PM)
PM'd
And yes, there are 2 yellow R34's around Monash, one is mine, the "pretty clean looking" one :(
Lol i was gonna- the other one looks to "fast and furious" for me. Your one looks pretty tough. How do u find parking there lol i reckon its almost impossible!
I "think" this fella "might" live on Rathdown St Carlton. I see that car parked there late at night when I go to my friend's place....
Not sure about the other details - all I remember was dark rims - but the GT wing sticks to mind and there are not too many yellow skylines. I never seen it actually running.
Not that I'm stalking.... :(
Parked next to a black S1 R33 (with SAU stickers) on Southland rooftop last night.
Must've been there for a long time. I had dinner, saw a movie and when I got back to my car it was still there :(
Also... This morning around 9am I spotted a black S13 with SAU stickers turning onto Boundary Rd from Lower Dandenong Rd.
s13 prob was me. What car were u driving..?
Haha thanks dude :(
Well... to get a parking there, you'd have to be there at 9am lol, coz I think between 7am-9am, it's no standing, then from 9am-4pm is parking, then from 4pm-6pm is no standing again. So at 9am on the dot, there'd be no cars there :P
Also it's $4.50 for the whole day hehe
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
