Often see a Grey/silverish R32 gtr on my way to work, on mt dandenong rd around the Croydon area. Black rims with tuff offset and black boot lip. Dunno if you're on here but that thing's awesome!
im guessing thats me lol :D
Spotted Red R35 GTR plate GTROAR parking on Toorak rd this evening, very nice car, and then saw another black/gun metal R32 not sure GTR or not but sounds nice along Toorak Rd just around the Monash freeway exit.
Spotted my dad in brunswick while going to check out an s15............. Funny how his got bigger plates too! lol
Whoever you are, lets go cruising, it'll be a laugh :D
Heres a photo :)
u stand on ur head to take that pic? :P
Haha 2 slow cars boosting it past you laith :)
My brother and mate. I'm waiting to see those cars written off. It will happen. Oh and try avoid unr3al. He has no insurance lol
I was stuck behind a little excel doing fifty... ...when I checked if it was clear to change lanes I saw CR34M about 500m back... ...so I just stayed there to check him out... ...didn't see UNR3AL until he went "tut tut tut" on my right side... ...then do you think I could change lanes after that???... ...I did get behind an unmarked cop that also looked like he was trying to keep up with them too... :P
I was stuck behind a little excel doing fifty... ...when I checked if it was clear to change lanes I saw CR34M about 500m back... ...so I just stayed there to check him out... ...didn't see UNR3AL until he went "tut tut tut" on my right side... ...then do you think I could change lanes after that???... ...I did get behind an unmarked cop that also looked like he was trying to keep up with them too... :)
haha owned
white r33 s2 between apple peel and tempy shops - exchanged waves :)
then in Heidelberg stuck in the normal bottle neck traffic near the ford and honda dealerships.. spotted a black r33 with the plates 'sicjet' guy looked at me i waved he ignored me and looked away - should of known from the 'sic' in your number plates not to wave hey..
lol!
33 arrogance?
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
