Spotted a silver 33 with purple vinyls on Princess round 3ish...I saw you wave sorry I didn’t wave back I was holding my new front bar because was getting in the way of the driver
That's ok... ...I didn't see your stickers until I was passing you...
A bit later on princess I spotted a black 32 GTS-t "TQ?-???"... ...dude looked like he was picking his nose as I passed him...
finally met the owner of NOGTR at the thousand steps yesterday. good to see more members lurking around there.
and just as i got back to my car at knox this arvo to find him parked next to me lol i wish i had my white nismo seat covers on then we would look identical except black n white :D
Looks like today been my day to spot R34s 1-on westall rd.silver R34sedan @2 pm
2-turning on westall rd. silver R34 coupe @3 pm.
3-on cheltenham rd.silver R34sedan @3.20 pm.
4-on narre warren nth.rd silver R34 sedan @ 7.30 pm
5-on Krispy kreme in Narre Warren the famous R34 painted like a japanese police car @7.45 pm.
Plus the day before yesterday (?) white R33 coupe at neighbour's house and whie R33 passing by on Magid drv.
Edited by southern_tango
Spotted a silver 33 with purple vinyls on Princess round 3ish...I saw you wave sorry I didn't wave back I was holding my new front bar because was getting in the way of the driver
NO SHIT!!! i have seen that car around... didn't know u were on here....nice vinyls though ;)
Saw ZILLA-33 in Caulfield not long ago :)
Was it black with twin pipes sticking out the back? it was side by side with me on the beach rd Elwood an hour earlier,
I think he wanted a run, after a while he did a u turn and headed back.
  • Like 1
  • Nope 1
Lmao, Zilla-33 is unlicenced. Defect Machine..... Been in it..
hahaha he got dick'ed and his still driving like krazyyy bad flamin mongrel
Yes it has twin pipes & its midnight purple gtr
  • Like 1
  • Nope 2
He wasn't driving like a dickhead, just cruzin, he buzzed around me for a while. yer midnight purple sounds about right.
Say no more.
  • Like 1
  • Nope 1
