What time did you see the r32? Could have been me? I was on Warigal road crossing princes hwy?
Think it was around 11:00pm ish, not later than midnight. Not sure if it had custom plates, sure it didn't, you wouldn't of seen me anyway as I was always a few cars behind.
Saw a red M35 Stagea turning onto Hallam-Belgrave Rd from Narre North Rd around 4:30pm tonight, nice. Also the same silver V35 coupe down Harkaway Rd minutes later, gave you a wave.
He said a nice R32 Pat :P
wasnt me then! carry on.
ha thats my gym too
i think we should go to gym together....
i will not be there today, its my rest day, but will be there tomorrow after 5.30 PM :)
if any of you see me, come and approach...ill be wearing a red and black stripe singlet and blue knee length shorts :)
Edited by lav
hahahaha....where did you park???i was looking for ur car :)
i was there about 6.30PM...i parked at the car park this time, there were no parking at the council....
i park in the actual carpark and not the library LOL i got there around 6:30 and left about 7:30ish when i saw your car..
will give you a shout bud! my missus comes with me too i just cbf going on weekends, so theyre my rest days lol
sounds good mate, will see you tomorrow around the same time :)
i also have rest day on sat or sunday....
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
