Saw a silver R32 last night crash into the back of a Dodge Nitro on Hampton street right near the corner of marriage road...
Didn't see too much damage though, skyline bloke locked the brakes up but didn't stop in time... unlucky buddy...
spotted a orrange Gts green p plates last night plates were something like JDR33M at the new car wash in chelsea heights.
Little message for ya mate when u take off from the wash bay, don't drive like a dick and plant your car round a blind corner where people walk to and from their car to get change from the money changer because im always there and last time i saw a guy do that he hit a lady walking back to her car and it didnt end well for that p plater after her bf pulled him out the car and im sure he learnt his lesson. just slow down mate no rush!
Kris (CR33M) again up Wells road just after Highway Tyres. while i was on my way to work
Lol yea was going with my bro to get his car dropped off. He was infront of me ( purple r34 4 door with white rims)
I see Larry Bird's Aussie bratha!
Saw a few Skys today, gold R35 GTR heading towards Knox on Burwood HWY and black/white R33 GTS on MT Dandenong. All behaving very well and no mods out of place :thumbsup:
Meanwhile a XR6 ute and previous model SS tried to drag me today. Hoons.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
