  • Replies 1.9k
Fast fours are looking after all the media side of things so your best option for that is to email nathan@hot4s.com and ask him as he will be the one giving them out not us.
Cheers
-Nathan
What about recreational photographers? Will there be any areas where non-accredited photographers will be denied access?
How about over 1 sec quicker then JP at PI in crappy, cold and damp conditions. It wasnt wet wet, but there was light rain through the day and even for the brief moments when it was dry it was still frezzing cold and miserable. Better, dry conditions would no doubt be quicker again.
Friggin cheaterer cars :banana:
I'm not 100% on what the story is with this Andrew I would suggest you email Nathan as he will be able to answer that because he is taking care of all the media side of things.
Cheers
-Nathan
I foolishly got all warm and fuzzzy and confessed to Snowman what's under the bonnet now..... Super duper cheaterereer
I will concede that after looking at what times you did at PI in those shitty conditions, i wondered what had been done to your car. I know you had been having overheating problems etc and didnt really get a chance to stretch the cars legs last year, but such an improvement in those conditions, well you are too good a driver to get those sorts of times from mpre track time (ie you are already good, so any improvement wont be seconds (perhaps only tenths) around a race track) Look forward to seeing the car in good conditions.
I really dont think street tyres, obviously they will need to be good ones, is going to hurt the good cars that much. Good suspension and brakes and power only make the car quicker then a lesser car on streets. My car is all gripped up on semis as the tyre masks so many other faults. A well sorted car doesnt need to hide behind tyre grip as you only need a lap time for a single lap
Less grip from the rubber will certainly be interesting. I think the main improvement with my car now is the suspension. The new engine is 390rwkw vs the old engine at 360rwkw. The oversteer issues seem to be ironed out now to the point where I am a bit scared to see how fast it will actually go around a corner ...
a good/well sorted setup for semis won't neccesarily work on road tyres. you generally need a softer, less aggressive setup to get the best out of any kind of low grip condition - whether its caused by rain or tyres...
as for power only making you faster even on street tyres - you've never seen lower powered cars further up the results in the wet?
Did some testing at Winton yesterday for the first time and got some footage. Still have heaps of work to do on the setup if I want to get anywhere near some of the quick RWD's in open class\
Enjoy
name="wmode" value="transparent"></param><embed src="
type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>&">
type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
Yeah its too soft in the front atm.
1.36.30 which im really happy about as there is so much more to do in the handeling department. Cant wait to see what it does on good tyres.
There were other laps that felt faster but dont have times for them wouldnt have been too much better.
Well done Adz, great time considering your still setting up the car.
I'd say there's at least another second in it without touching it, your lines on some of the corners are robbing you of time.
Big things to come yet from BIGRED...
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
    • Tomei or Nitto, don't use the OEM one or Cosmetic ☺️
    • After cleaning up a rusty cooling system in a 33 gtst that's been sitting for years it seems to have cleaned out the head gasket too haha. It seems the Tomei metal gasket works without machining surfaces? Or put oem? Also should put an oil restrictor while the head is off? Thanks
    • Thanks, I definitely saw the more expensive options from Crank and driveshaft shop. Thank you for the D-max option.  Still hopeful someone has an OEM out of the box option I found that the 300zx NA Left drive shaft is a good match for the Right on the R33. https://www.gsplatinamerica.com/product/ncv53040 Just need to find Left CV for the R33, I cannot find any <=22" axles.
