Sensational drive there Boz!!!
I own a turbo s2k as well and I fully understand how twitchy this high powered, short + narrow wheel base car it can be. After seeing how you steered I realised why I can't drive my s2k as fast as my bnr32.......I need LOTS of lap time with it. Very inspirational drive Boz. If you do come to QLD to teach, please drop me a PM. I will try my best to attend :ermm:
PS I am surpised that Elias has not put a roll cage in that car yet :D Do you know the weight of the car?
Edited by 9krpm
  • Replies 1.9k
lol Elias has thought about it. Because it has never been a specific track car and was/is his daily driver/toy it would probably just make it a little too hard to carry his kids.
I would think it is a fair bit heavier than standard. I am pretty sure a standard car is 1200+kg. Maybe you would know the standard weight.
We shouldn't get carry away with Honda on a forum like this lol
I wont post some rolled s2k pictures to scare you but yes you are right honda claims that the car is something like 1250kg but I think that is a dry weight. Still too heavy for a little thing.
It looks like you had a lot of practice in this s2k. You seem to know exactly how the car behave.
Edited by 9krpm
Was there any 180 on the day?
I'm sure they weight a bit the same, a good set up 180 or s15 would still give that Honda a good run for its money.
LOL West, watch the video again :P My car could perhaps even go close to the S2000, only it wouldnt have had Bozman driving it :(
The car use to have a GT35 when it was running straight line stuff. It now runs a GT32 to give it some mid corner speed at the track.
I think a good set up 180 or S15 would give it a run.
Practise lol if you call 4 or 5 laps in the car around Oran, I suppose you can call that practise :P
Edited by Bozman1
Holy moly! nice lap mark. that is stupid fast. There is such a big gap from say say 1:20 down to the 1:12s you guys were doing in the 32. Especially considering it's still a road based car. Very impressive especially so when you consider mark has done less than 50 laps of Oran park by my count.
Geeez, the R32 is hauling ass. Well done Mark, great effort in being less than second behind the Lotus.
I must say I'm more impressed with the R35, the times Russ was punching out in standard trim with standard rubber is amazing.
Will the R34 be ready for the next one Russ??? Rumour has it its in 3 months time...
hey guys just thought i would let you know i have posted up a lap of mark running around
http://au.youtube.com/watch?v=pEd_wBgrr7w
Hehe just past auto sport s15 @ the start, Get back in a Gtr Greg!!!!
nice video!
what's even more impressive about the 35 times is the speed de-limiter stopped working half way through the day! I think Russ' best time was set with the limiter working. :(
Comparing that to the S2000 vid you can see that with more practice around OP Mark would definitely go faster. Or maybe just let John Boston drive next time... :(
Different cars, different tyres and need to be driven differently. So i dont think you can say Mark is giving away much behind the wheel jsut from looking at that vid
Nice vid Russ and it gets going out of corners well. I can't wait to see in car vid thea the Ignition DVD crew took with in car camera in the boat with Bozman driving, and sure to be handfull and taily compared to Marks drive.
    • Not too sure just yet, want to have a go at doing what I can myself, but to start with want someone to cast their eye over it tell me what needs doing to get it running and back on the road, so anyone with great overall knowledge would be ideal.
    • I personally would go with cutting out the rubber. Then deal with getting sleeve off separately. Rubber can be painful to cut, it loves to jam up cutting tools. I normally have success with drill bits, deburr bits, angle grinders, jigsaw, reciprocating saw, and never forget... fire. Obviously different tools won't work in all locations you're trying to work with, and you need to be comfortable with each. You personally may be happy slowly slicing it out with a razor blade, if you are, go for it with one too! Feel free to wait for others to weigh in also on their thoughts.
    • So ... I got everything disconnected and started dropping the frame. Three of the four mounts started to come down but the fourth one (the one with the nut that gave me all the trouble) won't budge. The inner metal sleeve stays up tight against the chassis rail although the outer part of the mount drops a bit (and can be levered quite a lot more) but it's just stretching the rubber bushing. So I reckon there's some serious corrosion inside the inner sleeve and holding it tight to the lug at the top of the bolt. Tried everything I can think of so far: penetrating oil, whacking the top of the sleeve to vibrate it and wedge a screwdriver blade in there. I also tried to turn the inner sleeve a bit by hitting it with a chisel at the bottom. It's stuck solid. What do you think about cutting the rubber with a blade so I can drop the subframe around it anyway. Then worry about getting the inner sleeve off after? Will that work? Is it gonna give me even more problems?
    • Steam valve seals are usually responsible for cold start smoke, it goes away once engine warmed up. Disconnect it let engine breathers and let it breath freely, see if problem goes away after a short drive. Also check to make sure engine oil drain pipe is not blocked or kinked.
    • Haha thanks! Yea I'm moving over from 2x 1000cc jets pre throttle over to 6x 190cc direct port jets and 1x 500cc pre throttle jet.  Direct port comes with all the advantages you would expect, except that pre throttle does cool down IAT'S more. That's why my direct port nozzle placement is closest to the plenum as possible in the runners to allow the air more time to cool before being sucked in. I'm also putting that one 500cc pre throttle jet to help with more cooling. It's a hybrid system. There's a lot more advantages to moving over to a PWM solenoid with a constant pressure system vs my old PWM pump setup, but I'll get more into that once I'm done converting everything over. The ricer in me is excited to see SS tubing all over my manifold though!
