Hi guys
Not sure if this trend have been posted before and probaly a stupid questions.
But I just want to know what fuel you guys usually use with the Skyline and have you notice any differences in milage, power, idle etc.???
I have always pumped Shell Optimax as I though they have the highest octane and some cleaning agents in it. But I just found out in some other treds that some people also use BP Ultimate and Mobile fuel.
If it is the case I'm more happy to change to BP as it is right next to my place and is cheaper than Optimax.
Cheers
if you're ever anywhere near a place that sells evolution 98, try it out. i get measurably lower knock values on the pfc when compared to mobil and bp stuff. optiomax was worst of the bunch for me.
Adrian
Guest RedLineGTR
Originally posted by CerealKiller
yeah this has been questioned many a time before.
Optimax has reduced in quality the RON rating is variable servo to servo. The most consistant seems to be BP Ultimate and Mobil Syngery 8000 which are both 98RON.
sounds about right bro..
Guest RedLineGTR
Basically i would recommend to type other fuels at least once. Some cars run better on certain types and some dont but Optimax is rated at a max of 98ron when brands like BP ultimate are rated at 98ron or more but in most cases they arnt much more than 98ron+. Alot of people have at alot of bad batches of optimax etc. My 2 cents.
Thanks for the feedback guys.
I think i will make a switch to BP Ultimate. But doesn't all BP as Ultimate now instead of Premium Unleaded?? I'm only guessing because the Ultimate would replace the P.Unleaded, like Optimax replaced their P.Unleaded.
Cheers
I know this may upset some people but in my experience, I tried
Shell Optimax and it was the worse thing I could have done.
Quality changed from servo to servo, and in fact the car lost power. I am not sure if it is related but my Oxy sensor went bust and had to replace it. Read some guys had problems with Optimax and blew their Oxy sensors as well. Like I said, I am not sure it is related to Optimax. I swicthed to Ultimate and car runs smoother and stable fuel economy. I haven't tried anything else.
very intresting comments....i have been wondering for a long time what the superior fuel is....i have been using optimax since i bought the skyline, almost 2 years, not really had any had problems, however after reading the above comments i am eager to experiment with BP and perhaps Mobil.
its all the same LOL ... just try most of them out ... u will find that different cars will react differently to the petrol depending on the way its tuned ... i've tried lots of petrol in my car ... just about all i can think of .. even normal unleaded for half a tank to see how i went ... needless to say ... not good in terms of mileage and power ... the best for me is regular pulp .. bp that is ... probably the cleanest is bp out of all the brands from what i know ... low sulfer or whatever their advertising is ... but yeah i use that cause its 5cents cheaper and gives me more economy ... beats me why?? hehe .. i want to know how these engines will react to all this ethanol the government is trying to support for the poor sugar growing farmers ...
Prediction:Federal Government legislates that all regular fuel must have a small % of ethanol. Premium Fuels exempt , HOWEVER a new levy (read TAX) to be introduced to "offset negative revenue stream". (Because they know there will be little effective opposition. The fuel companies will go along with it and the media couldn't give a stuff)
[/cynicism]....:D
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
