Hey this is my first post!
I recently bought a 1996 R33 GTS-T Series 2. Has done 94k and just recently had an engine rebuild.
Just wondering what i should look at firstly! im wanting to get abit better fuel economy as im only getting around 300k atm with mixed driving using boost rarely. I think its running around 8psi. Stock turbo and theres a really dodgy looking jaycar boost controller in the passenger footwell.
The car also is backfiring a bit and goes crazy if you rev over 4500rpm :)
What should i be looking at? ECU? Coil Packs? o2 sensor?
Thanks guys. :rofl:
https://www.sau.com.au/forums/topic/211940-bad-economy-and-backfire/
If you have a aftermarket blow off valve that vents to atmosphere and doesnt plub back, try fitting the stock one or a plumb back one. The air that vents to atmosphere has already passed the o2 sensor therefore telling the computer that its getting that much air,.. in turn more fuel is added and the extra unburnt fuel can cause a backfire when backing of the accelator. Not a bad thing that it runs a little rich but just annoying having the backfire and maybe some black runoff on the back of your car yeah?!
A tune on the dyno will fix it up if its the air/fuel ratio but even still the plumb back item is much better for the car
LOL at Nick :D
Could be alot of things. Goes crazy after 4500 rpm is a bit of a general statement. If its miss firing then look at coil packs for hairline craking (very common on RB25). Or check plug condition and gap. If its only running 8 psi then a gap of around 1.0-1.1mm should be fine without causing a miss.
If its running too rich then maybe check out your AFM, sometimes they will test out ok but can still be faulty, so on occassions its just easier to try another known working one. Cleaning the AFM shouldnt be necessary as Nissan's use a 'hot wire' AFM which as the name suggests uses a heated element to sense air flow. The more airflow, the less heated the element becomes resulting in less resistance. More heat, more resistance. Thats how the ECU reads what the AFM is passing. Anyway when they are turned on they heat up burning off most contaminants. They will commonly cause back firing from over fuelling and and misjudged mixture control if not operating correctly.
An O2 sensor is in the exhaust so anything running through the intake pipes has deffinetly not seen the O2 sensor. I think your thinking about the AFM. its true though that will cause the unmetered air effect and can screw up the mixture.
A tune on a dyno is useless unless you have some form of tuneability in the ECU whether its a piggy back system or a full computer swap, etc
Resetting the ECU will only wipe trouble codes that could help you fix the problem, it can temporarily fix the issue but its not normally a permanent fix. Theres no reason to run retarded ignition timing on a rebuilt engine. Should just be run at optimum settings.
So check all of the above:
Plug condition and gap (1.0-1.1mm)
Coils for hair line cracks
AFM for correct output voltage
Look for any form of vacuum leaks. You can use aero start to identify if and where the leak is by spraying it around the hoses. The revs will change if there is a leak
Perhaps check the TPS also for correct output voltage. Should be 0.5 at closed throttle and 4.5-5v at full throttle.
In checking the TPS also make sure the Idle switch that is built into it is reading closed when its closed and vice versa.
Check for correctly adjusted ignition timing.
But honestly my guess will be a miss fire caused by either plugs or coil packs.
The list goes on, EFI diagnosis is no easy task.
Good luck :D
That Jaycar Boost controller is far from dodgey...
A dodgey O2 sensor will not cause backfiring, sounds like a fcked up timing as other have pointed out
Coil packs, will cause the car to mis fire & splutter, and perhaps backfiring
ECU, I doubt it would be the stock ECU
Backfiring is usually from restarted timing. loosen the screws on your crank angle sensor and turn it full clock wise if it pings wind it back a tad.
Also check that your igniter is earthing properly, my car was running retarded timing even with CAS turned fully clock wise until I ran a separate earth wire too my igniter.
Dont touch the timing mate, your a newbie by the sounds of it and dont have to much idea what your diving into. Leaning out your engine could make it ping and eventually blow it..
Please take it to your mechanic, and if it has a ECU upgrade which I assume it does please skip the mechanic and to a tuner and ask them to squeeze some more kms out of it.
Please keep in mind that a new engine requires to run somewhat rich to run it in to prevent any mishaps, such as pinging. How long ago was it rebuilt?
Edited by DECIM8
My car is now having problems idoling i wonder if its related? when i start the car in the morning i have to give the accelerator a bit of a press as the revs start to drop thats never been a problem before. Also the revs have started going up and down...like on a few occasions when the turbo timer is on. It goes from arount 750-1200 up and down, sounds like someones just tapping the pedal like this /\/\/\/\/\/\/\ Is this at all related?
+1
The engine was redone around 1000km ago now. I dont want to touch the CAS as i know nothing about it. im not sure if its stock ecu or not either...yep im a newbie :blush:
Yes, stuffing around with the CAS isn't worth it. A tuner can fiddle with it in 5 mins and costs you very little.
Could be many a thing. A stuffed sensor (i.e. O2), bad plugs, a leaking injector, BOV problem, idle control issue. If you're not prepared to go through every single thing then give a measly $100 to a mechanic and they'll tell you in 30mins exacly what's wrong.
Then pay him another $1000 to fix it hahaha :down:
jk, jk.
mine had idle problem very similar, i changed the plugs and got rid of the miss, but i still had it idling up and down.
so i cleaned my throttle body. stopped it from fluctuating. but be careful when cleaning throttle body, apparently there is a seal around the butterfly, dont rub it of as i did. it will cause your car to idle at 1500 and while driving at 2500!. but i have adjusted my tps to drop the idle until i build a new seal around the butterfly.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
