They're all bad drivers in Malaysia. I try to avoid that country, but alot of my OS flights have a stop over there :ermm:
One of my transfers one time drove past a fatality. Bodies hadn't been covered just yet.
But what a waste of a GTR :ermm:
Well, like Sewid, ive driven the car ( numerous times ) and i can say that it has more than enough power to get you into trouble but you would have to be doing something extremely stupid to get to that point.
Its ridiculously fast but at the same time, able to handle driver errors...unless you try to make it do something it was never designed to do...hence the wreck we now see before us..
What is that? The 3rd one?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
