How strong is the stock crank shaft?
Will it handel 500-800hp every day?
Are their any upgrade options that dont require a 5 year loan to afford?
and while i'm at it, would my rb20det computer chipped for 550cc injectors and z32 MAF be a good base map for a rb26/30 (with an E-Manage Ultimate on the side) or would i be better off machining my stock heads and putting large valves in it?
Edited by LedZepLen
well mines running 700bhp/660lbs @ 5800rpm and 8000rpm redline no problem done 1000 miles in it now and ran it on track at 2 bar all day, with a 26 head and gt35r 1.06 rear..
it will def need custom rods ( which I will supply also ) and possibly custom pistons, might get away with RB30ET pistons - depending on final displacement / swept volume.
what will need to be changed to run this setup ? just the crank ? or the pistons and rods too?
Awsome timing, i wanna start that project next winter. I hope to have the largest displacement rb in North America. I'm the only person in my city to have a modified Skyline so far but i hope it catches on as i'd like to start importing in a few years. Since it's an unkown car here it needs to live up to the legends arround the model name (apparently i can CHIP 1000hp, hahaha).
what kind of oil pump upgrades did you do if you don't mind me asking?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
