hi mate. the oil pump is nismo n1, the crank has a collar fitted. and all the clearances where checked with plastigauge.. i.e endfloat was checked with feeler gauges, and mains/big ends/oil pump-collar gaps were checked, also its all balanced ..bernie
Edited by rockabilly
i was being sarcastic as thats not an overly accurate way of measuring clearances lol
Furry muff.. is there a better way to measure clearances with everything torque'd down?
Oh and when I decide to take my RB30 passed 400rwhp I reckon I'll get one of your cranks to go with the new rods.. 3.4L FTW :thumbsup:
G`Day all,I would like to know what some of you have done o standard crank`s if it worth spending any time cleaning them up cast mark`s ?,weight loss ???,cheer`s chuckie.
If big capacity is wanted why don't you guys go the the nissan v8s ?
While that would be fun it was too much headache and then turbo'ing it would be a nightmare.. the idea is still floating around in the back of my head so maybe one day :laugh:
Chuckie, all I did to my crank is have it ground for oversize bearings. My engine isn't going to be seeing huge revs or MASSIVE power for quite some time, when I get to that stage I'll re-do the crank aswell as new rods etc (or likely get one of these 3.4L cranks :bunny:)
On that note, these bigger cranks.. will they already have the long oil drive and all the other goodies people do to their cranks (grub screwing etc)?
Well from all the advice I have received (forum users, tuner and mechanic), 400rwhp seems to be an acceptable cap for now. When I decide I want more, engine will come out and get new rods and a balance along with some head/manifold porting.
more interested in what kind of RPM limit it can handle - especially so after a balance and knifeblade.
are the rods more likely to go before the crank at higher revs?
RPM is far more savage on the up & down bits (pistons and rods) than the round & round bits (crank). They have to stop, change direction and accelerate, then stop, change direction and accelerate again etc while the crank simply rotates. I could see the probability of 1,000 bhp out of a standard crank, but 1,000 bhp out of standard rods is not in my wildest dreams, pistons forget about it.
Cheers
Gary
SK, I might be misunderstanding, are you saying that if the revs aren't excessive then the rods should be able to handle a lot more than 4-500hp? I have my 30 limited to 6800rpm, reckon I would be able to push more than 400rwhp on the stock rods with that limit?
RIPS have pushed the stock rods and pistons to 750hp on nos a few times for fun, then wind it back down to 600hp for the street...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
