just half moon slot the sides of the conrod on the edge of the bearing seat, side face. Simple :wacko:
what are you on about?
bearing seat? you mean the tangs (little notches in the big end tunnel of the conrod) or you talking about the actual big end tunnel or big end journal?
1/2 moon slot the sides?
i was talking in reference to oil squirters....
not the tang. I said on the side of the conrod. ill put up a picture...pretty well most conrods have this done nowadays...
i understand but i think they ment the oil squirters that sit in the crank case area just under the sleeves
i believe this is about as good as it gets as its pretty painful to setup a proper oil squirter system like those in a 25/26. Admittedly it would be good for reduced piston heat...but your also adding more oil to the windage foundation. And that is an area that not alot of people look at, or even know exists.
  • 3 weeks later...
i did find a 100mm rb stroker crank through one of our customers, he is asking for 7400 for the kit, though with some v6 stroker cranks from them the quality wasnt the best, on dummy assemble we found the strokes varied per cylinder and we had to off set grind a plus 30 to rectify
  • 4 weeks later...
I have 2 RB30 stroker crank samples , 12 custom rods and 12 custom CP pistons due mid July. A trial engine will be assembled and run, then if all is ok production will start.
So hopefully all things being equal Ill have kits ready to go Nov/Dec this year.
I just received my first CA18 and SR20 stroker cranks - pics or of CA18 87.6mm
Edited by Spoolup
Nice work! look like I'll be building a 3.4L on the side come Xmas :P
I put a post on the NICO.com CA18 about the cranks, they were interested a while ago when i mentioned in a thread about aftermarket CA rods that you were making a stroker crank. Keep an eye on it if you want.
Here's the NICO thread i'll post one up on NS.com as well;
http://forums.nicoclub.com/zerothread/4341...ker-crank-876mm
P.S. whats the cost of the CA crank?
EDIT!!
The NS.com thread;
http://www.nissansilvia.com/forums/index.p...howtopic=393047
Edited by D_Stirls
  • 1 month later...
  • 1 month later...
does anyone know if you can buy the colar that you screw onto your crank, or do you make it?
my engine builder is asking me to find out as i think he didnt put one on when he built my 17k RB30/26 build of only 2000k before it broke the brand new N1 oil pump gears the first time i gave it a decent rev.
whats the best option?
Aproxx 600rwhp
Yes you can buy collars (Spool, among others, sell them).
Not exactly screw on though, you have to machine the snub of the crank down, press the collar on then drill/tap for grub screws.
Edited by bubba
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
