Give the person doing the machining the block and ask them to find out if the block will need to be bored out then get your pistons based on that. Not every brand of piston/ring combo is made for the same tolerances, too big and you get blow by and lots of piston slap issues too small and the pistons may not even move when its up to temp.
Whats why you bore the block to suit the pistons...
So basically, the engine builder might say "the block needs boring out 20thou (0.5mm)" so then I'd go buy some 20thou oversize pistons and the pistons would come with a spec sheet detailing the required bore clearances, which the mechanic would use to bore the block to the correct size?
  • 3 weeks later...
yeah, we dont want to re-invent the wheel here.... if only they would make a piston with a small dome.. :P problem solved
Dave, there are dome top pistons for the twin cam 30. Arias make them 9.2:1 CR, they also make another slightly higher CR piston also but cant remember what it was.
Edit. Found the info.
p/n= AP332104
10.6cc dome top
21mm pin
1.280" compression height
Only stocked in 0.20 thou oversize (86.5mm).
COMPRESSION RATIO 9.2-9.4
p/n= AP332105
13cc dome top
21mm pin
COMPRESSION RATIO 9.5-9.8
Edited by TiTAN
hey im just after a quick hand..
i have found some dirt cheap forged arias pistons with 8.5-1 comp ratio with the single cam head..
what would the comp ratio be with my rb25de head??
thinking around 7.8-1??
is their any down sides to decking the block to get higher comp ratio??
id like comp ratio of around 8.6-1..
cheers tom
  • 9 months later...
  • 1 year later...
Using either the RB25 or RB26 head on the RB30 block you need to use RB30E pistons the RB30ET pistons will result in a far too low compression ratio to be much use as a street car.
Hey guys sorry to revive an old thread. Im also building a 25/30, R33 S1 turbo head and RB30 turbo block and as TITAN said it will give me way to low compression ratio (to my liking anyway). I was looking more between 8.5-9.3 compression ratio. I dont want to spend a fortune on forged pistons (Im only looking no more than 350hp atw), so i was thinking more towards getting stock pistons. Do you guys recommend getting a RB30 NA pistons or should I go more towards RB25 NA/Turbo pistons?
Sorry for the n00b questionsclosedeyes.gif any help would be greatly appreciated
Thanks in advance.
http://cgi.ebay.com/...8#ht_1055wt_907 ermm.gif
  • 2 years later...
Sorry to dig up such an old thread but I searched long and hard and I can't seem to find the answer. With stock rb30e pistons and a r33 s1 rb25det head (obviously rb30 block) does anyone know how much I can deck the block before valve piston clearance etc becomes an issue? The block is stock as a rock no previous decking as far as I know
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
