Not sure if I will be driving yet but Im in for helping!!
Has this been put in Canberra as well??
Need to let the ACT guys know the NSW peeps will be in town :ermm:
Me and Doof on Skidpan duties again :D
Also Helpers will be reward for there efforts... if your not up for driving guys or dont have a car but still want to come we will appreciate all the help we can get!!!
  • Replies 410
Posted Images
I'll have a drive zilch
I was fastest 33 there last time :ermm:
p.s. its not hard to get the licence guys :D
AASA you dont need to be a memeber of an affiliated club like CAMS
CAMS - member of SAU NSW, can get your licence
People, as much as we'd all be stoked that you bring your Skylines, Stageas, Silvias/180SXs/200SXs, etc. along, don't be afraid to bring whatever you have available - one of the quickest car/driver combo's last year was TURISMO in his Aussie-spec EP91 Toyota Starlet, which he COMPLETELY (and I mean COMPLETELY) gutted for the day out on the track.
And Yes, you will need a helmet too! Mainly for the back track, as evil_weevil mentioned...
Yep, if you become an SAU-NSW member, you will benefit from the cheaper entry fee for this and other events - but there are other benefits as well.
Ando, seeing as you no longer have the JapTaxi, are you going to enter your AusTaxi?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
